Author Topic: YAMAHA 4TH O/S RINGS DT360A  (Read 5377 times)
« on: November 05, 2007, 09:48:58 pm »
hi
can rings be bought for this size i think they are 81mm 1mm o/s.or do you have to buy gen
jimg
Re: YAMAHA 4TH O/S RINGS DT360A
« Reply #1 on: November 05, 2007, 10:02:34 pm »
nope any 360 yam will fit just check the correct end for pin.
If you buy the mx you can only run it on the second ring , if you use the dt kit piss off the dykes anyway run the bottom one.
I didnt bid on the piston set 3rd and 4th didnt you win em ?  :'(
« Last Edit: November 05, 2007, 10:05:34 pm by Freakshow »
« Reply #2 on: November 06, 2007, 09:36:28 am »
kerry
after my op i lapse in and out of smartness just depends on the day.i have another 5 weeks of this
« Reply #3 on: November 06, 2007, 09:43:39 pm »
Freaky that's arse about run the Dykes leave the second ring out.Less flutter and better sealing.
« Reply #4 on: November 07, 2007, 02:34:18 pm »
meh..... more shit to fall in the hole i reckon.  either way JImg you can ram whatever you like so long as its a 360 it can go on the 2nd ring, or if you have a dyke left use that.  so long as you got a ring on it you ll be fine.
