Author Topic: Liquid intelligence 239 for motorcycle??  (Read 1511 times)
Offline 1983_Enduro_YAMI
« on: November 14, 2016, 01:57:59 PM »
G'day,
I heard that the Liquid intelligence radiator flush works pretty good in car and truck radiators....would this suitable to use in aluminum motorcycle radiator that holds 800ml of coolant. if so, how much do I need of this to treat the radiator??
Re: Liquid intelligence 239 for motorcycle??
« Reply #1 on: November 14, 2016, 02:36:39 PM »
a lot of cars now days run alloy blocks/heads and radiators so should be ok as long as you give it a good flush,as to ratio's why not use it to the makers specs
« Reply #2 on: November 14, 2016, 02:49:09 PM »
Thanks Matt, I will for sure but the instruction says "Mix the required dosage of Part A cleaner in a separate container with about 3 to 5 litres of hot tap water. Stir until completely dissolved (one scoop of powder treats per litre of cooling system capacity then pour it in and top up with tap water" If I mix up 3L if water, what am I going to do with the rest of the water??? It only holds 800ml of liquid or maybe I can scoop 3/4 of the spoon so treats 0.8L but how much water I need in the bucket to mix up 3/4 spoon of water??
« Reply #3 on: November 14, 2016, 06:56:43 PM »
another point    just make sure the bottle says its suited to alloy head/radiator cooling systems
