Author Topic: Essential restoration equipment  (Read 10849 times)
Offline skypig
Re: Essential restoration equipment
« Reply #30 on: November 15, 2016, 08:00:29 PM »
A 12 ton press, or access to one.
After failing with two smaller presses I put my lower triple clamp and steering stem in the big girl and crushed the alloy "spacer"/support I'd made.
I then positioned it straight on the steel plates, applied pressure till I was a bit scared, hit it with the heat gun for a while and - success. It moved for the first time in 35 years (I assume).
Soon I'll have tapered bearings top and bottom  8)
« Reply #31 on: November 15, 2016, 09:53:31 PM »
  A wheel spanner and a couple of tomahawks.  Watch the clip below
https://streamable.com/20pa
Good ol' ussie ingenuity hey ;D ;D ;D
lucky der brudders had a gubba to organise them ;D ;D ::)  ;D
