Author Topic: Essential restoration equipment  (Read 10848 times)
Re: Essential restoration equipment
« Reply #15 on: October 09, 2016, 03:04:00 PM »
You forgot skill set of a fitter turner boilermaker spray painter
Offline steve234
« Reply #16 on: October 10, 2016, 12:54:01 PM »
So glad I put this one out there cheers !
Bultaco M106 Astro
Wanted: Dirt track bikes / parts / info
Offline skypig
« Reply #17 on: October 10, 2016, 01:23:43 PM »
"Time serts" (and "Thick serts ") are something I've discovered.
An expensive but sometimes useful alternative to helicoils.
A helicoil removal tool has proved useful. Especially if somebody has already "restored" the bike.
As mentioned. An Ipad with Ozvmx as the home page is indispensable.
Offline Butcher
« Reply #18 on: October 10, 2016, 08:42:12 PM »
$50 doesnt buy much these days, but have a mate with particular skills and a love of BEER and slab of the breweries finest will get that job done....
« Reply #19 on: October 10, 2016, 09:09:38 PM »
maybe we should have a post about "sh*t that has gone wrong" in that shed with all those tools and machines...
Offline yamaico
« Reply #20 on: October 10, 2016, 10:05:49 PM »
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, ‘Oh sh–!’
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle… It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
SON-OF-A-B!TCH TOOL: (A personal favorite!!) Any handy tool that you grab and throw across the garage while yelling ‘Son of a B!TCH!’ at the top of your lungs.. It is also, most often, the next tool that you will need.
« Reply #21 on: October 10, 2016, 10:17:39 PM »
He he he ;D ;D ;D ;D ;D
« Reply #22 on: October 11, 2016, 06:30:46 AM »
a ripper and oh so true...
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #23 on: October 11, 2016, 08:00:28 AM »
Classic!  ;D ;D ;D
« Reply #24 on: October 11, 2016, 01:11:12 PM »
A Shed .. aka workshop/piss up ,bullshit and swearing domicile ........ ;)
Offline FAT-TOY
« Reply #25 on: October 11, 2016, 03:00:52 PM »
  Not essential but would be nice
https://www.youtube.com/watch?v=cOTunqOXu30
        Zane
Everyday I find one more name to add to the list of people who piss me off.
« Reply #26 on: October 11, 2016, 08:22:34 PM »
« Last Edit: October 11, 2016, 08:26:17 PM by Lozza »
Offline Paulos
« Reply #27 on: October 11, 2016, 09:12:51 PM »
you forgot a couple Pete:
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt
holes and is ten times harder than any known drill bit.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets
in their holes until you die of old age, but it also works great
for drilling mounting holes in fenders just above the brake line
that goes to the rear wheel.
TIMING LIGHT: A stroboscopic instrument for illuminating grease
buildup.
TROUBLE LIGHT: The mechanic’s own tanning booth.  Sometimes
called a drop light, it is a good source of vitamin D, “the
sunshine vitamin,” which is not otherwise found under motorcycles
at night.  Health benefits aside, it’s main purpose is to consume
40-watt light bulbs at about the same rate that 105-mm howitzer
shells might be used during, say, the first few hours of the
Battle of the Bulge.  More often dark than light, its name is
somewhat misleading.
AIR COMPRESSOR: A machine that takes energy produced in a
coal-burning power plant 200 miles away and transforms it into
compressed air that travels by hose to a Chicago Pneumatic impact
wrench that grips rusty bolts last tightened 40 years ago by
someone in Sindelfingen, and rounds them off.
Offline yamaico
« Reply #28 on: October 12, 2016, 03:18:02 PM »
Haha, good ones Paul.
Offline FAT-TOY
« Reply #29 on: November 15, 2016, 05:21:28 PM »
  A wheel spanner and a couple of tomahawks.  Watch the clip below
https://streamable.com/20pa
