Clubroom
Tech Talk
90* Airfilterbend
Topic: 90* Airfilterbend (Read 6834 times)
ola_martin
90* Airfilterbend
May 08, 2016, 07:18:18 am »
Hello.
I just started making sidecovers for my Cheney Honda XL350 sideport.
I need a 90 degree bend from the carb (Mikuni 36) to the airfilter (through the sidecover)
Any ideas where or from what bike I can find one??
ola_martin
Re: 90* Airfilterbend
May 08, 2016, 07:20:01 am »
ola_martin
May 08, 2016, 07:21:06 am »
ola_martin
May 08, 2016, 07:24:50 am »
Preferably a bit longer than this one, so I don't have to use the alloy tube.
mick25
Hunter valley NSW
Reply #4 on:
May 08, 2016, 07:42:11 am »
You Could try radiator hoses from cars etc from your local car parts store I did this on one of my projects.
Gezz your work shop makes mine look real bad
Moto
A-Grade
Reply #5 on:
May 08, 2016, 08:28:03 am »
Try looking in a car wrecking yard.Cars have all sorts of rubber tubes for air intakes and air conditioning/heating.
John Orchard
^^^ July 1984
Reply #6 on:
May 08, 2016, 08:58:43 am »
I needed a hose for a bike I did recently; I needed a 90 degree bend followed by a 45 degree bend with 45mm ID, found the perfect item on ebay for $9 :-)
mboddy
A-Grade
Canberra
Reply #7 on:
May 08, 2016, 09:22:17 am »
What about this 1977 to 1979 Yamaha YZ125 IT175 boot. The smaller diameter end clamps to the Mikuni 34mm.
Vinduro Penrite Team
LWC82PE
Superstar
Reply #8 on:
May 08, 2016, 11:37:47 am »
http://www.mackayrubber.com.au/products/
They do universal elbow bends
EML
Ride the World before it Rides You
Reply #9 on:
May 08, 2016, 07:24:36 pm »
we use a lot of bends when doing trbo and inter-cooler work, available from ebay, hot rod shops, and some trucking suppliers, in lots of colours too, red, blue, yellow, green etc....
ola_martin
Reply #10 on:
May 09, 2016, 05:39:22 am »
Thanks for all the tips guys!
I'll look into the carparts then.
I just hope it isn't super thick reinforced rubber in them.
The YZ part looks great, only I think it's a bit short, I'd really like the joint to airfilter to be well inside the cover.
I just want plain oldscool rubber, no high gloss or coloured silicone.
Mike52
81 KTM 125 LC
Reply #11 on:
May 09, 2016, 07:32:04 am »
Coming along nice that bike .
Friend struggling up a hill on a old bike at MTMee .
http://www.youtube.com/watch?v=cjj6E2MP9xU
FourstrokeForever
AKA Mark H #35 VCM
Reply #12 on:
May 09, 2016, 10:24:55 am »
You could also try a plumbing supplier, they have all sorts of bends and connectors.
Very nice bike by the way. The only thing that could make it better would be if it was mine!
brucey
C-Grade
Reply #13 on:
May 09, 2016, 10:09:03 pm »
Ola have a look at fuel filler hoses and ADBLUE diesel hoses around the filler area as these are not reinforced typically and nitrile they are about 3.8 to 4.2 mm wall
(Volvo Truck)
Also GMH hoses and Opel are typically the thinest at 4mm- 4.5mm wall EDPM hoses
Sorry you are not that close but i do work for the last Australian Hose manufacturer
Good Luck with it mate A truly Stunning Build by the way
Bruce
TT5 Matt
Reply #14 on:
May 09, 2016, 10:29:28 pm »
what about the 77/78 huskies they used a 90 degree bend as the airbox was mounted side on like the yz/it's.ask big k on here as he's a lover of all things husky
Clubroom
Tech Talk
90* Airfilterbend
