Author Topic: Wanted : RM250A/B centre engine case gasket  (Read 1726 times)
Offline micko
« on: July 12, 2015, 08:00:15 PM »
As it says, desperate for one.
Offline Tomas
Re: Wanted : RM250A/B centre engine case gasket
« Reply #1 on: July 12, 2015, 09:34:09 PM »
would not be hard to make one from sheet of gasket paper. centre gaskets are usualy 0.4 mm thick. used to make centre case gaskets for my jawa 50. never had a leak. give it a go
Offline Nipper
« Reply #2 on: July 13, 2015, 08:57:21 AM »
Pretty sure they are still available. Part number 11481-41101.
Give your local Suzuki dealer a call.
Offline micko
« Reply #3 on: July 13, 2015, 04:18:22 PM »
Unfortunately Nipper there backorder ex japan. Might have to make one as Tomas said.
Offline micko
« Reply #4 on: July 13, 2015, 06:00:26 PM »
All sorted, found 1 at Mick Hone  :)
Offline Doc
« Reply #5 on: July 13, 2015, 06:33:27 PM »
On a side note..if you do make your own centre gasket the thickness many early suzukis use is 0.60mm. Anything else may cause shifting issues ;)
« Last Edit: July 22, 2015, 05:38:26 PM by Doc »
Offline micko
« Reply #6 on: July 21, 2015, 07:52:45 PM »
Found that out on my 370 Doc, put it together without a centre gasket and found the shift drum stuck out of the case a wee bit to far (gasket thickness) and rubbed on the locating plate. Damm, I wasn't pulling it apart again.  A bit of recessing/grinding on the inside of the locating plate fixed that baby.
