Author Topic: Fork oil RM125B  (Read 3988 times)
Offline YZAT252
Fork oil RM125B
« on: April 10, 2015, 12:18:22 PM »
Hi Guys, can someone tell me the right quantity and best grade / type of fork oil to put in my RM125B? Also, how much air pressure?
Re: Fork oil RM125B
« Reply #1 on: April 10, 2015, 12:38:50 PM »
Offline YZAT252
Re: Fork oil RM125B
« Reply #2 on: April 10, 2015, 01:33:38 PM »
That is awesome, thank you for that, will come in real handy.
Re: Fork oil RM125B
« Reply #3 on: April 10, 2015, 02:20:18 PM »
Offline Daryl Jones
    • Old Bike World
Re: Fork oil RM125B
« Reply #4 on: April 11, 2015, 09:35:16 AM »
A Ton (or two) of really good information, Thank-you.
cheers, DJ
Life's too short not to try to do Everything.
"First they tell you you're wrong, and they can prove it.
Then they tell you you're right, but it's not important.
Then they tell you it is important, but they knew it all along."
Charles Kettering.
Offline YZAT252
Re: Fork oil RM125B, what weight?
« Reply #5 on: April 16, 2015, 09:56:27 AM »
What weight fork oil do you recommend? Original manual says 20W, with 20psi of air, thinking maybe 15W Motorex??
Offline sleepy
« Reply #6 on: April 16, 2015, 06:47:51 PM »
Why do you think lighter would be good? Are the forks stock internaly?
I have an old Shell oil manual and it lists 20 fork oil as 59 CST at 40 degrees closest non fork oil to that is Tellus 68 which is a hydralic oil. I have used it and the 32 version of it in the past and it works well.
The original oil and pressure specs assumed a rider of around 60kg and if you are like the rest of us I'd start with a little more pressure and oil weight and give it a go.
