Author Topic: Maico 490 101 for dummies  (Read 11713 times)
Re: Maico 490 101 for dummies
« Reply #30 on: January 27, 2014, 12:59:40 PM »
Are you building a bike to fit an era? Pre 85 or evo? If it's a pre 85 then get the later motor.
Exactly, work out what class your running and buy a motor for that class, you seem to want to do a  whole lot of cutting and pasting of motor components that will do nothing except make your wallet a whole lot lighter...
yep you are right, dumd arse here is on a learning curve = to a brick wall so teasing out options seeing were to go or not to go with the guidence of you Maico Guru's I may have half a chance ;)
« Reply #31 on: January 27, 2014, 01:02:24 PM »
Shelpi just give Les at Mainly Maico  a call .(02) 4981-7241  He is the man to talk to about Maicos .
Thanks Wasp will do ;) cheers
