Author Topic: RM 125 gearing  (Read 1138 times)
Offline Nipper
RM 125 gearing
« on: September 21, 2012, 09:14:55 AM »
I thinking of using 13 - 55 gearing for my RM 125 B is this around the mark for motocross ? And if the bike was to be used for dirt track what would be an acceptable gearing ratio ? Cheers Nipper
Re: RM 125 gearing
« Reply #1 on: September 21, 2012, 10:06:18 AM »
I run 13/59....tried other ratios.....13/53....13/57.....59 is a good allround gearing.....MX and DT.
Offline asasin
Re: RM 125 gearing
« Reply #2 on: September 21, 2012, 10:21:07 AM »
depends on you weight and throttle hold on ability ;D ;D ;D
Me I need 10 : 86 just to get out of the gate. ;)
13/55 only if you are lightweight otherwise at least 13 /57
« Last Edit: September 21, 2012, 10:27:03 AM by asasin »
If in doubt ,WIND IT OUT
Offline Nipper
Re: RM 125 gearing
« Reply #3 on: September 21, 2012, 10:39:40 PM »
Thanks for the info guys.This bike is being built primarily for my daughter to ride so the 55 rear sprocket will probably do as that is the largest I can find at the moment. and If I am going to ride it can I get one of those 86 tooth sprockets from you Asasin ?
