Author Topic: Tm 250 build up  (Read 4848 times)
Tm 250 build up
« on: May 20, 2012, 07:02:51 PM »
This was a ex  Andy Caldecott bike of which I purchsed last year. It's a 1973 frame and had most of the basics needed to make a start.
Stripped it right back and bead blasted Due  it having  a far bit of surface rust of which was not that far gone
Welded on a few tags to take Rm B style rear guards - re- shaped the rear loop more to my taste - added 2 frame threads to take seat base ( rear ) added a rear tank mount  and moved the seat frame to take the new style seat ..... Cut the shit out of the frame to remove some excess weight   ie  front frame connector and  just above the air boot junction
Here is a comparison in weights in bar frames from a TM  to TS ... a  Ts frame is much lighter
Offline PERM250
Re: Tm 250 build up
« Reply #1 on: May 20, 2012, 07:08:21 PM »
Looks great will be watching this rebuild stew. You got all the bits for this ONE .
albrid-3
Re: Tm 250 build up
« Reply #2 on: May 20, 2012, 07:09:30 PM »
That is true as I had a ts400 frame and it was lighter than a Tm 400 frame.
Re: Tm 250 build up
« Reply #3 on: May 20, 2012, 07:23:33 PM »
Now for the seat .... I purchased a DC base and used a Rm 125 b  base as a template .... in my case I mounted the front seat bracket 10mm further forward  pushing the seat back as the tank was cutting into the cover .
You will need to make up some brackets, as the bar seat bases come blank, they are held in place with pop rivets on the foam side
Re: Tm 250 build up
« Reply #4 on: May 20, 2012, 07:29:10 PM »
The air box is another of my creations made from a pot using a Rm / Pe filter cage ( covered this in another post )
« Last Edit: May 20, 2012, 07:34:14 PM by oldfart »
Offline smed
Re: Tm 250 build up
« Reply #5 on: May 20, 2012, 07:57:35 PM »
I hope that wasn't the cooks favourite pot oldfart :D
Offline crs-and-rms
  • heaven 23
Re: Tm 250 build up
« Reply #6 on: May 20, 2012, 08:03:45 PM »
love the air box
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: Tm 250 build up
« Reply #7 on: May 20, 2012, 08:23:21 PM »
so, you should be able to boil up a cob of corn while riding then Stu?
"flat bickie"
Offline bazza
Re: Tm 250 build up
« Reply #8 on: May 20, 2012, 08:39:03 PM »
Feck me Stu what will you boil the Ducks in now!!!
Embrace patina
Offline mick25
  • Hunter valley NSW
Re: Tm 250 build up
« Reply #9 on: May 20, 2012, 09:00:11 PM »
I used the same idea with the air filter  8) but mine was a stainless steel peanut container from wollies .
All kiwis must think alike ;D I am always looking at diffrent things that may be used on bikes.
Look forward to the project stu
Re: Tm 250 build up
« Reply #10 on: May 20, 2012, 10:01:44 PM »
  got himself two smokers now  ;)  Bikes lookin good oldfart, shed time ahead  :Pj
Offline tmman
Re: Tm 250 build up
« Reply #11 on: May 20, 2012, 10:25:14 PM »
are you f...kn serious old fart... its not a TM... or a TS special looks more like an 'ol STEW pot' special.. now instead of playin with that lovely creation... what happened to my airbox??? n 25 i ave some milo tins here that are exactly the right size for the actual tm aircleaner can!!! but bein an aussie i thought best keep it original  ;)..
Re: Tm 250 build up
« Reply #12 on: May 21, 2012, 11:53:06 AM »
love the airbox Idea, very clever.
should work well on the TM/TS slow cooker  ;)
Re: Tm 250 build up
« Reply #13 on: May 21, 2012, 11:59:12 AM »
Nuthin slow about a TM Hoony  ;-)
Re: Tm 250 build up
« Reply #14 on: May 21, 2012, 04:56:48 PM »
And Here she is all tarted up .... just need to get a few laps in before the Nats
