Marketplace
Wanted
Need bent/damaged parts frame for Kwaka Z900/1000
Topic: Need bent/damaged parts frame for Kwaka Z900/1000 (Read 1017 times)
MX?
September 18, 2011, 07:34:12 PM »
OK sorry it's not VMX....but it is V.
Just thought I'd throw this out here in case someone may be able to help.
Tim754
Northern Country Victoria
Re: Need bent/damaged parts frame for Kwaka Z900/1000
September 18, 2011, 10:47:10 PM »
I have one (Z900) that has been converted to a speedway sidecar, no engine. would swap frame (front end , sidecar etc not included) for a K series cb750 frame to convert to same as I do have the odd 754 donk. Cheers Tim754
Last Edit: September 19, 2011, 03:52:55 PM by Tim754
MX?
September 19, 2011, 05:57:06 PM »
This is the obviously not my frame but shows the main section I'm looking for...rear indicator brackets.
Don't know if your frame still has these.....if it does, I may be in trouble anyway coming up with a CB frame unfortunately.
Tim754
September 19, 2011, 06:30:42 PM »
Yep not there. Still that photo you have is a good place to start making your own maybe
Marketplace
Wanted
