Author Topic: YZ125 H 1981 Reed Valve Upgrade  (Read 8122 times)
Re: YZ125 H 1981 Reed Valve Upgrade
« Reply #15 on: October 03, 2009, 11:15:32 pm »
Not really Geoff, if the plate is radiused on the downward side it's no problems.Without the radiused stop plate the petal is more flexible.Like the ruler over the desk type thing ;)
« Reply #16 on: October 04, 2009, 01:43:44 pm »
That's just it, the plate looks square edged to me.
Ji Gantor
« Reply #17 on: October 04, 2009, 04:05:35 pm »
Geoff I know what you are saying and I agree the sharp corner should be the other way around but this is how Boyesen recommend you install them.
Ji
subanator
« Reply #18 on: October 17, 2009, 02:47:14 am »
Apparently smoothing the leading edges on the petals with 800 grit paper will stop the edges feathering and will last longer.
Ji Gantor
« Reply #19 on: October 17, 2009, 08:13:37 am »
Good tip
Ji
« Reply #20 on: October 17, 2009, 12:06:02 pm »
Smoothing the ends helps but oil is what prevents the ends fraying. It acts as a cushion between the petal and cage.
