Author Topic: kawasaki F6 125  (Read 10969 times)
Offline jimson
  • Sanctuary point N.S.W
kawasaki F6 125
« on: September 26, 2009, 07:41:11 pm »
G'day viewers I've been offered a F6 125 for $200 its rough but going and its seems all there would these be any good for dirt track pre75.  :-\ jimson
« Last Edit: October 03, 2009, 02:16:30 pm by jimson »
Offline Noel
Re: kawasaki F6 125
« Reply #1 on: September 26, 2009, 08:10:37 pm »
Hi,
I would say the F6 could be made to go pretty hard, rotary disc induction lends it self to some tweaking,
If your not interested I may be.
Noel
Re: kawasaki F6 125
« Reply #2 on: September 26, 2009, 08:27:27 pm »
Shocker, just stick it in a box and send it to me....... ;)
Offline jimson
Re: kawasaki F6 125
« Reply #3 on: September 26, 2009, 08:34:35 pm »
Lozza how much $ would you have to through at the engine to make it move. Noel I'll let you know whats happening after this monday   :-\ jimson
Re: kawasaki F6 125
« Reply #4 on: September 26, 2009, 11:05:25 pm »
Without looking inside it, I couldn't say exactly. Really down to port/pipe/ignition/carb replacment and changing the disc timing.If you have a suitable ignition and carb that's 2 things you don't need. ;D A lot depends on the gearbox to.One thing to check is if it has a complete cast iron cylinder some models have and some have an iron liner in an aluminium cylinder, the ali barrels are the ones to have.Just send me a pm if you or Noel don't want it.
Offline geraldo
Re: kawasaki F6 125
« Reply #5 on: September 27, 2009, 07:02:15 am »
an F6 was my 1st bike , loved it to bits , eventually blew it up ( dropped the skirt off the piston ) . I was told when I bought it that it had been taken out to 175cc - it went very well
Offline jimson
Re: kawasaki F6 125
« Reply #6 on: October 03, 2009, 04:19:36 pm »
Lozza what would be a good ignition to replace the old one  :-\ jimson
Re: kawasaki F6 125
« Reply #7 on: October 03, 2009, 06:37:23 pm »
Any 80 or 125 would be OK
Offline jimson
Re: kawasaki F6 125
« Reply #8 on: October 04, 2009, 02:33:43 pm »
G'day viewers just wondering do I need to keep the oil feed on the F6 or can I just pre mix the fuel in the fuel tank ? jimson
DR
Re: kawasaki F6 125
« Reply #9 on: October 04, 2009, 06:02:39 pm »
Jimson, if it's a Superlube model then yes and if it's the Injectolube model no. Pretty sure the injectolube is on the larger models and you have the Superlube but get a more definate answer from someone in the know ;)
Offline jimson
Re: kawasaki F6 125
« Reply #10 on: October 06, 2009, 08:30:19 pm »
Thanks Doc I'll keep the oil lube on the bike.I was looking through my stash of bits today and saw a pair of KL forks and triple tree and maybe a 21 front wheel if this all comes together I might put some rego on the kwaka and use it for a practise bike in the scrub  ;D .jimson
« Last Edit: October 06, 2009, 11:01:16 pm by jimson »
Offline JC
Re: kawasaki F6 125
« Reply #11 on: October 10, 2009, 10:44:50 am »
Jimson,
If the KL forks don't fit it'd be worth considering late 70's 32/33mm 185 Suz forks, triples & front wheel. IIRC the triples have 25mm stem like F6.
They could do w a longer swingarm & wheelbase too. Again, 185 Suz should fit straight in. Or MT125 Honda at a pinch. I'm in the process of doing it to my bros F7. Some 185 Suz wheels had alloy rims too.
F7 175 top-end should fit straight on too if you want more beans
« Last Edit: October 10, 2009, 10:51:55 am by JC »
Re: kawasaki F6 125
« Reply #12 on: October 11, 2009, 03:06:15 pm »
beware though as the stock piston(and the TKJR) will go BANG (the pin boss will disintergrate) when you go over 26 RWHP for any length of time.
Offline JC
Re: kawasaki F6 125
« Reply #13 on: October 13, 2009, 11:57:23 am »
Loz,
What RWHP can you pull out of the 125 F6 engine/barrell?
« Last Edit: October 13, 2009, 02:13:48 pm by JC »
DR
Re: kawasaki F6 125
« Reply #14 on: October 13, 2009, 01:30:57 pm »
do the little kawa's have a bottom end issue also whereby the rods tend to fly apart at high rpm? I swear someone mentioned this once when I was planning on doing some mods to my KH125 :-\
