Author Topic: Road bike throttle bodies.  (Read 1462 times)
« on: September 06, 2009, 10:13:14 pm »
OK, so its not Vintage and its not anything like MX - but there are plenty of people out there with bits stashed under benches...
I'm looking for a set of throttle bodies (the carbs for EFI bikes) from a ZX12, early GSXR1000, or GSXR1300.
The important details are:
Each butterfly must have its own shaft (not one or two long shafts joined).
The butterflies must be at least 42mm in diameter.
Not worried about any of the other details, inclusions or so-on.
This type is right - see the little linkages between each butterfly: http://cgi.ebay.com/ebaymotors/gsxr-1000-throttle-body-fuel-injection_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem25563064c3QQitemZ160359802051QQptZMotorcyclesQ5fPartsQ5fAccessories
This type is wrong - see how the lingakge is only between the middle two TBs and they sort of look like a pair of twin carbs:
http://cgi.ebay.com/ebaymotors/03-04-2004-Gsxr1000-Gsxr-1000-Throttle-Body-Bodies_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem3a524a8ccfQQitemZ250488720591QQptZMotorcyclesQ5fPartsQ5fAccessories
If you think you can help, then give me a yell and we can work it out for sure.
Nathan.
04000 23847
Edit: I have a set of R1 TBs that are no good to me because there's two long shafts, rather than four short ones. Will happily sell or swap for the right type.
« Last Edit: September 06, 2009, 10:15:31 pm by Nathan S »
Re: Road bike throttle bodies.
« Reply #1 on: September 06, 2009, 11:34:28 pm »
For $10USD what are you waiting for ;D What Volvo engine are they going on?
« Reply #2 on: September 07, 2009, 07:30:57 am »
Someone who will ship to Australia.
Yes, I know that there are ways around this, but time is running low....
Its a B23E. Should be good for ~140kW at the rear wheels once the long rod, light piston bottom end is built. Probably be limited to ~120 on the stock bottom end - which is still more than 99.99% of Datsuns.  ;D
ChrisACT
« Reply #3 on: September 07, 2009, 09:38:47 am »
B23E?  Isn't that the donk out of the 242GT?  I think Robbie Francevic used to like turbo charging those.  ;)  I have seen a worked 242GT Turbo blow a Porsche 911 turbo into the weeds.
The gentleman driving the Porsche didn't think it was very funny.
« Last Edit: September 07, 2009, 09:42:01 am by ChrisACT »
