Author Topic: SUZUKI RM 500 FRAME  (Read 12440 times)
Re: SUZUKI RM 500 FRAME
« Reply #15 on: September 07, 2009, 08:47:40 pm »
Nada , I take it you have found a Dr 400 frame ....if so read thru DRM postings
Rear   was a Rm graft  plus Rm swing arm ....not off the same model bike.
EML    PE 250 -400 forks  are a straight swap into a Dr 500 ;)
Offline EML
« Reply #16 on: September 07, 2009, 10:12:28 pm »
I 'spose they are but I will need leading link in this fella!!
Offline nada
« Reply #17 on: September 09, 2009, 10:15:08 pm »
yeah my frame is a DR400, ill grab a set of PE forks for the old girl, and put an RM twin shock rear in it!! i have decided to try and keep it a close to its erra as i can. thanks for all your help everyone. special thanks to you OLDFART- i will probably have some more questions for you as my project starts to gain pace.
NADA ;D ;D ;D
Nada
Honda is the only way to roll!
Offline nada
« Reply #18 on: September 10, 2009, 05:33:49 pm »
with the PE forks, will i be able to use the DR tripple clamps or shoud i use the PE one's?
Nada
« Reply #19 on: September 10, 2009, 06:33:55 pm »
Pe triples are the way to go .   Or even a set of Rm 125 -250  years 79 -80  ( 38mm fork) will do
and just change over steering stem    ;)
« Last Edit: September 10, 2009, 06:37:10 pm by oldfart »
« Reply #20 on: September 11, 2009, 12:09:33 pm »
all-bird,
Found the t&t with rm/4 stroke article, want it let me know.
« Reply #21 on: September 11, 2009, 03:46:25 pm »
Evo , Is that your old DRM forsale on Ebay down NSW way ????
« Reply #22 on: September 11, 2009, 04:05:07 pm »
Oldfart,
Not sure, the article is on a rm456 fitted with a xt (sr) 500 motor.
