Author Topic: Pre 85 Legal Modifications  (Read 14174 times)
Ji Gantor
Re: Pre 85 Legal Modifications
« Reply #30 on: August 28, 2009, 08:36:28 am »
Thanks Holeshot Buddy for clearing that up. Do you know what forks and brakes they are?
Thanks you for giving me that nut to hold on my kick lever at the Nationals, it worked a treat.
I have just installed the OEM nut and have another in my tool box if required.
Ji
Offline Tex
« Reply #31 on: August 28, 2009, 09:33:41 am »
So, are the USD forks Pre 85 legal or not? Were they really around in 1984?
Ji Gantor
« Reply #32 on: August 28, 2009, 09:41:41 am »
So the story goes Simon's released a set in 1982 and WP also had a pair for sale.
So if these are the Pre 85 models which so many have suggested that they are then yes these two bikes are period correct.
The Simon's USD of that period cost $5000.00 if you can find a pair.
Ji
Offline holeshot buddy
  • sunshine coast qld
« Reply #33 on: August 28, 2009, 10:52:24 pm »
simons forks were availiable to the public in aust
in 1983
white power were in 1984 on production ktms with drum brake only
follow me to first turn
Ji Gantor
« Reply #34 on: August 30, 2009, 08:09:26 am »
So Holeshot what type of USD forks are they on the bike Scott rode at Coolum?
Ji
« Reply #35 on: August 30, 2009, 10:28:49 am »
For a bike to run in that configuration (and be considered legal) you would need solid evidence that a bike raced using those components prior to the cut off date. Just because a component was available doesn't automaticaly make it kosher.
« Reply #36 on: August 30, 2009, 02:22:33 pm »
you have done your homework JI! yes there were early WP4054's back around 82, most likey only in europe and as prototype/test models/limited sets made before the production set came out on 84 KTM's No one can yet confirm exactly when they were available as aftermarket forks yet though.I have listing for WP4054 Non adjustable -revsion set #R601 1982-1988.
In my opinion, if you get a set of drum brake 4054's off a 84 KTM and then machine your own lower axle mount/cailiper carrier for your YZ with CR forks or what ever you want them for? then that would be perfectly legal because A) The forks are off a pre 85 model and B) the caliper carrier is custom made and not a off the shelf part from a later model as back in 84 someone could have done exactly the same thing and wanted 4054's on a yamaha or honda or what ever and got a set off a KTM and then decided they wanted a disc but from what i can gather there was no WP 4054 caliper carriers at all in pre 85 so they would have had to make their own. There is debate whether a 1985 or 1986 set of WP4054s are legal for pre 85 even if they are proven to be the same design internally and exteranlly as the 84 KTM forks even if you convert to drum brake or take off the 'factory built' 85 or 86 caliper carrier and built your own, so the only way i think you could safely do it with no arguments is to use a 84 KTM set of 4054's or one of those earlier limited production/prototype sets from europe the later which you would never find anyway.
There was a set of 'works' USD Ohlins forks on ebay this year, i dont think i saved the photos but there was some history behind them origiinating back to Belgium? The seller said they were 82 models however forum member Marc FX believed they were 85 model Ohlins USD forks and not 82 as the ebay listing said but he or the seller may not have been right or wrong.
« Last Edit: August 30, 2009, 02:29:04 pm by LWC82PE »
Offline NSR
  • Sunshine Coast
« Reply #37 on: August 30, 2009, 10:11:28 pm »
Ji
You may have already seen it, here's a thread on another forum about Simon's forks.
I can't seem to link it with it translated.
http://www.mxteam.com/forums/lofiversion/index.php/t19123.html
Noel
« Last Edit: August 30, 2009, 10:17:34 pm by NSR3 »
The Swvm though the tree's! http://youtu.be/4h6BbasT16I
Metalink Conondale vinduro sprint. May 19/20 2018
www.metalink.net.au  Bike trailers & Canopies
Ji Gantor
« Reply #38 on: August 30, 2009, 10:27:35 pm »
Hi NSR3,
I see the Simon's forks but do not speak French so the words are all Dutch to me.
The axle connection at the base of the forks are very similar to Scott's bike, they must have been milled up.
Thanks mate
Ji
« Reply #39 on: August 30, 2009, 10:31:19 pm »
the forks on the yz 490 were simons
geoff still has the bike ;)
Offline NSR
  • Sunshine Coast
« Reply #40 on: August 30, 2009, 10:36:34 pm »
Ji
Google it, then click on translate.
Noel
« Reply #41 on: August 30, 2009, 10:47:37 pm »
JI its french, just go to babelfish to translate it. It worked for me.
