Author Topic: IT 250 Clutch actuator arm  (Read 2129 times)
lc4
« on: August 22, 2009, 08:26:35 pm »
Can someone point me to a site for a free parts manual or exploded views of the RH case and how the clutch actuator arm is retained. Have a friends bike were the whole assembly is poping out from the case.
Offline AdamN
Re: IT 250 Clutch actuator arm
« Reply #1 on: August 23, 2009, 07:06:59 am »
Try,
www.nwvcp.com
Go through and use the drop downs to find your bike and all you need will be revealed. They are highly recommended if you can't source parts locally too.
Adam
'82 PE175Z, '92 YZ125D1, '93 WR500ZE, '13 KTM350EXC-F, '16 Husky TE300
lms6201
« Reply #2 on: August 23, 2009, 08:09:15 am »
 1981 and later the return spring holds it in , if the crankcase has chain damage around the seal lip u may have to make up something like a piece of alum bent to go over the top of the arm and fix it to the sproket cover bolt , also if the part of the actuator that contacts the pushrod is bent the wrong way it can act as a wedge and try to push the thing up when it takes the load , pre 81  has a steped screw that engages in a slot in the act. shaft
lc4
« Reply #3 on: August 23, 2009, 09:41:13 am »
This sounds exaclty like what is going on. I was puzzled that there was no obvious physical means of holding it in other than the spring.
Thanks.
Offline yzhilly
  • Melbourne
« Reply #4 on: August 25, 2009, 07:38:12 am »
The clutch cable has a Retainer clip that hooks into the case and keeps it close to the case.
Viper #436
Offline Viper666
    • Ballarat Rovers MCC
« Reply #5 on: August 25, 2009, 09:44:08 am »
This used to be the best site for online parts viewing till they stuffed with it.
Still pretty handy though
http://www.yamaha-motor.com/sport/parts/home.aspx
