Author Topic: YZ490 1983  (Read 17437 times)
Ji Gantor
YZ490 1983
« on: August 11, 2009, 09:31:41 am »
Hi all,
I lost a part from my bike at the Nationals and was hoping someone may be able to sell me one.
I need the retaining nut for my kick starter.
I would also like to retro fit the YZ490 1983 leading edge front brake to my YZ125 1981 if any body has the front brake assembly they would like to sell.
Ji
lms6201
Re: YZ490 1983
« Reply #1 on: August 12, 2009, 05:37:04 am »
nuts are readily available new for the 465/490,  , which brake plate do u want ? 490 has horizontal lug , 465 has 45deg   , i think the 15 might have 45deg ?
Ji Gantor
Re: YZ490 1983
« Reply #2 on: August 12, 2009, 06:40:30 am »
Hi IMS,
I rang Yamaha yesterday and they only have one of those nuts left in Japan and if I want it, it will cost $115.00.
I can get a standard nut from a bolt company but it will not be flanged nor nickelled.
I will check to see what angle is required today and let you know. Do you have a 465 brake assembly for sale ?
Ji
« Last Edit: August 12, 2009, 06:50:36 pm by Ji Gantor »
Ji Gantor
Re: YZ490 1983
« Reply #3 on: August 13, 2009, 12:16:45 pm »
The front brake assembly is at 45 degs so yes the 465 front brake is the go.
Ji
Offline Woody
  • Heaven #70
Re: YZ490 1983
« Reply #4 on: August 13, 2009, 02:00:10 pm »
I don't mean to hijack Ji's thread, however I'm also after a DL edge front brake set up to suit the '81 YZ125H hub.
Guys, which other models apart form the 465 will suit so I know what to keep an eye out for?
If there are any others for sale after Ji gets his, please let me know.
Woody
WANTED
1988/89 125 - CR KX YZ
IT200 stuff
CR250RD parts
Offline sa63
Re: YZ490 1983
« Reply #5 on: August 14, 2009, 10:52:09 am »
Hi
I think I have a spare TLS plate. I get back to Bris. Tues. Could probably machine up a nut-for  beer? wont be  plated but can be blued and hardened.
Will look when I get back.
Sean
Offline yamaico
Re: YZ490 1983
« Reply #6 on: August 15, 2009, 10:58:08 pm »
Hi Ji,
I have a YZ490 backing plate that I bought from the states for my YZ465 but it doesn't fit as it has the 45 degree angle. It doesn't have any brake arms or linkage rod. Any good to you? I'm still chasing the correct one for the 465 if you happen to come across one.
Pete.
Ji Gantor
Re: YZ490 1983
« Reply #7 on: August 16, 2009, 09:02:52 am »
Hi Yamaico (Pete),
I am trying to get a backing plate with all the extras so thanks for your offer.
Hi Sa63,
Is the TLS plate you mention the brake backing plate?
If so I am interested please let me know when you get home.
The nut I can buy from a fastener company for 95 cents but it is not flanged nor coated. If no one has a genuine Yami one I will just buy one of these and save the problems.
Ji
TwoTees
Re: YZ490 1983
« Reply #8 on: August 16, 2009, 12:56:19 pm »
Did you find a nut yet?
These guys say if it you can add it your cart, then they have it their in stock....$3.87us
http://www.nwvcp.com/pages/parts/viewbybrand/default.aspx
They also have an ebay shop and their shipping is realistic.
Chris
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: YZ490 1983
« Reply #9 on: August 16, 2009, 01:06:13 pm »
"flat bickie"
Ji Gantor
Re: YZ490 1983
« Reply #10 on: August 16, 2009, 01:09:24 pm »
Hi Vandy,
That is for a YZ490 I think.
Thanks for the heads up that would have been great value.
Ji
Ji Gantor
Re: YZ490 1983
« Reply #11 on: August 16, 2009, 01:13:50 pm »
Hi Two Tees,
Thanks mate.
That is a great site for parts.
I will order some parts and see how I go.
Ji
Ji Gantor
Re: YZ490 1983
« Reply #13 on: August 16, 2009, 01:33:34 pm »
Thanks Paul,
I can not see the nut in that pile.
The nut is shiny nickle and has a flange like an attached washer.
It is also a half thickness nut.
Ji
TwoTees
Re: YZ490 1983
« Reply #14 on: August 16, 2009, 01:38:26 pm »
That brake on ebay is a 1982 yz 490 and on.
490 locating slot at almost 90deg from arm cams as per ebay picture.
465 slot up near top arm
IT's kept with the ealier type but had steel arms instead of alloy
