Author Topic: Late model YZ front in PE400  (Read 11531 times)
Offline holeshot buddy
  • sunshine coast qld
Re: Late model YZ front in PE400
« Reply #15 on: November 11, 2009, 09:52:15 pm »
i have a ts250x under the house i am sure the fork
dia is the same as the PE
and they are slightly shorter ???
follow me to first turn
Quicksilver
« Reply #16 on: November 11, 2009, 10:08:51 pm »
Interesting. Maybe they were marked wrong. Just measured them again, 41mm for sure. Heres a few exra pictures of clamps, maybe that will help with an ID. Bottom clamp is cast steel not alloy.
« Reply #17 on: November 11, 2009, 10:28:45 pm »
dont know what they are look a bit like tt yammy maybe
definately not tx 250 suzy
check date stamp on the rim ;)
Offline frostype400
« Reply #18 on: November 11, 2009, 10:33:30 pm »
And then tell frosty he needs a set. :)
1971 tm400 and PE's
Quicksilver
« Reply #19 on: November 11, 2009, 10:57:46 pm »
holesot... The rim won't help with ID mate its one I had from other bike, its a CR125 hub on 18 inch rim. ;)
I checked all over it front end for tell tail Suzuki S bolts. There are none!
« Reply #20 on: November 11, 2009, 11:15:12 pm »
i thought that was a honda wheel looking at hub
was gunna say something :o
 i still think they are yamaha ;)
but if they fit and are gunna work use em ;)
Offline frostype400
« Reply #21 on: November 11, 2009, 11:19:09 pm »
I'd like to know what they are so i can put some on a project of mine. Suzuki trees don't always have S stamped bolts alot are just stamped with a number thanks, Michael. :)
1971 tm400 and PE's
Quicksilver
« Reply #22 on: November 11, 2009, 11:20:08 pm »
I think your right. Looking a few sets of TT600 and TT350 forks ( after you mentioned it  ;) ) on USA ebay my fork legs look very close as does top clamp to TT Yamaha. The cast botom clamps seems to be very close in shape but the TT use's alloy.
« Last Edit: November 11, 2009, 11:22:10 pm by Quicksilver »
« Reply #23 on: November 11, 2009, 11:29:13 pm »
hex key fork cap as well ;)
ts250x forks would be ideal slide straight in original
triples not a bad brake slightly shorter in overall length from
top of fork to axle cant remember how much but its not a lot
i have a set i was thinking of putting on my pe400 as well
i certainly ride it fast with the drum brake
but thats only cause i cant stop ::)
Quicksilver
« Reply #24 on: November 12, 2009, 10:57:34 am »
The " Whatever " front end worked out well. Longer forks and smaller wheel married together nicely.  The ride height I think is very good, nice balance between front and rear. Got to do something with the guards  ;D PE headlight clipped on over the 41mm forks, speedo bracket holes lined up perfectly on the top clamp.  ;)
Offline frostype400
« Reply #25 on: November 12, 2009, 12:34:04 pm »
looking good Quicky, good to know that the pe headlight will pop on larger forks thanks Michael. :)
1971 tm400 and PE's
Quicksilver
« Reply #26 on: November 12, 2009, 01:21:59 pm »
Thanks Michael. I like that way its coming together.  ;)
That PE light is fairly old, soft and very faded, maybe that helped  ;D. Real test for fitment will come when I try a new repro light plastic. That is if I decide to go with a PE light.   ;)
Quicksilver
« Reply #27 on: November 12, 2009, 07:36:26 pm »
Here is a few more pictures of the forks. I hope they may lead to a positive ID on these.
Some possible's offered are Yamaha TT or XT600 or 350. Suzuki TS200 import model. Honda 81 model CR250. No one yet has been able to say " these are " Thanks to the blokes who have posted, PM'd or emailed a possiblity.
Quicksilver
« Reply #28 on: November 12, 2009, 08:07:39 pm »
emmmmmmmm. Forks look a hell of a lot like these.
http://ozvmx.com/community/index.php?topic=9973.0
Offline frostype400
« Reply #29 on: November 12, 2009, 08:21:45 pm »
Yeah they do look close it's hard to see if the little tab on the bottom of the forks is on those ones. I dont think it is I'd really like to know what ones work so I can get some for one of my projects thanks Michael.
1971 tm400 and PE's
