Author Topic: 1984 CR250 Clutch cover fail - any recommended repairers?  (Read 10973 times)
rls840
« on: July 25, 2009, 08:02:54 pm »
Got a beautiful 84 CR250 with the dreaded coolant leaking into the gearbox. Anyone recommend someone who could repair it. Hopefully there's someone out there who knows a good trick to keep it from doing it again anytime soon.
Re: 1984 CR250 Clutch cover fail - any recommended repairers?
« Reply #1 on: July 25, 2009, 08:19:10 pm »
Try emailing Bruce (Magoo) at www.red-devil-racing.com
rls840
« Reply #2 on: July 26, 2009, 03:27:29 pm »
Thanks for the tip Ross, I've sent those guys an email. Hopefully I'll get some success. Anyone else got any ideas?
« Reply #3 on: July 26, 2009, 06:07:08 pm »
Most of the time repairs are done with devcon or a similar product ( a 2 pac epoxy, liquid metal type product)
I've done the same repair to my Husky, not to hard, just make sure you remove all the affected magnesium.
STW996
« Reply #4 on: July 28, 2009, 06:01:01 am »
Hi rls840, they are a very hard thing to weld and I have 3 off these bikes and have Devconed them all. one has been done for over 3 years with no problems at all.
Shane
pimpolligist16
« Reply #5 on: July 28, 2009, 01:17:59 pm »
i have the same problem were do i find devcone?
« Reply #6 on: July 28, 2009, 02:25:22 pm »
Devcon - or other metal replacement mix - usually better auto shops.  Can also get 2 tube premix jobs which work well also.
Rossco
rls840
« Reply #7 on: July 28, 2009, 10:32:50 pm »
Thanks stw and Rossco. it has been fairly heavily devcon'd already but I guess a little more couldn't hurt!!! Is there any particular coolant that you recommend that is easy on the magnesium??
basil44
« Reply #8 on: July 29, 2009, 08:18:18 am »
Any peice of magnesium that comes into contact with water (even if mixed with coolants will only slow the corroision down) is going to rust! My advice to anyone is to treat or paint the insides  of any component be it engine cases,wheel hubs,backing plates ect ect because most of the little surprises we find are the ones we cant see. You dont have to paint the outside if you dont want to (if your after a certain look) because you can wipe it off and keep an eye on it. Water will seep into anything and then sit on the bottom under oil ect even in non water cooled engines. There are plenty of good products out their so theirs no excuse for not doing it. The worst thing with magnesium is trying to weld it so this is definnitly one for preventitive maintainance. Cheers John.
Offline zorroz
« Reply #9 on: July 29, 2009, 09:53:50 am »
I've repaired a few Hondas with the same problem over the years. Trick is to get rid of all the corrosion by having the affected area sandblasted. Then use JB weld and press it into it and shape it before it goes hard. The stuff is great and it shouldn't leak ever again. And I also paint the expose magnesium to prevent further corrosion. I had one on a Cr500 that rotted right through inside and out and worked great.
STW996
« Reply #10 on: July 30, 2009, 06:09:01 am »
rls840 all good advise from the guys so remember you are not alone on this one.
Go for the better brand of aluminium putty (devcon is a brand name an is one of the best), if you can bead blast the affected area first and then apply. If Pianting use the VHT hi-temp exhaust paint is sets like concrete and is very hard to remove specially if you do the baking process they advise.
Any good bearing shop stocks Devcon, it can be filed and even machined if applied correctly.
Shane
Offline flyingdg
« Reply #11 on: August 01, 2009, 07:13:44 am »
can the cover be welded up and then have it machined?
STW996
« Reply #12 on: August 02, 2009, 04:41:00 pm »
Well yes it can but you need someone who isa very good welded to do it as the alloy is not of high grade.
Shane
« Reply #13 on: August 02, 2009, 05:22:21 pm »
yes, as Shane said (providing it has never been repaired before by Devcon of similar stuff, if it has it must be TOTALLY removed before welding) there is a degree of risk getting them welded, you need to take it to someone that is VERY experienced in this kind of work, and has done it many times before with success. don't take it to someone who says "i will have a go"
« Last Edit: August 02, 2009, 05:24:38 pm by Hoony »
« Reply #14 on: August 02, 2009, 06:05:50 pm »
magnesium welding is a very expensive, each rod is worth about $20-00 each  :o and if he gets it too hot it will catch fire
Mega poxy is the same as Devcon ( and can be worked by hand in water ) drys in about 12 hours  ;)
