Author Topic: Cagiva WMX Piston  (Read 5407 times)
Offline AJ
Cagiva WMX Piston
« on: July 14, 2009, 09:57:15 pm »
Hi All,
I would appreciate help in finding a piston for a Cagiva WMX 190cc 1983-84.
Can anyone suggest options if a genuine or aftermarket item isn't available.
This is holding up the project.
thanks in advance,
AJ
Offline paul
Re: Cagiva WMX Piston
« Reply #1 on: July 14, 2009, 10:06:42 pm »
IS THERE A PART NUMBER
Offline AJ
« Reply #2 on: July 14, 2009, 10:20:37 pm »
Paul,
I gave a list of parts numbers to the guy who is assemling the engine for me.
l will get the number & post if this will help.
regards,
AJ
Offline paul
« Reply #3 on: July 15, 2009, 08:33:24 am »
i think we have our work cut out aj this is the first reply i got
paul
They are extinct. I was lucky enough to find one that has been sitting on the shelf since the 80’s after calling about 300 different husky dealers. I have 4 others looking for them as well. Wiseco will make you one but there is a minium order of 10. It might be worth it to call them and see if anyone has put a large order in and they will give you there contact info. I did this on a mugen build and got lucky. Every engine part is extremely rare and hard to find. I have been searching for everything to restore this engine for quite some time. Good luck.
If you don’t find one I might have a used one in good shape. I have two engines I have yet to tear down yet. So maybe one of them is good.
Barry Mann
Mustang Engineering, L.P.
16001 Park Ten Place
Houston, TX 77084
713-215-8069
[email protected]
Offline zorroz
« Reply #4 on: July 15, 2009, 10:29:09 am »
Offline paul
« Reply #5 on: July 15, 2009, 11:15:49 am »
paul
try Robert at Husky Rider, I think he has an ebay shop, I bought a NOS barrel, piston and head form him. or a new guy on the WMX 500 list who reckons he has lots of parts (even reckons he’s got plastic side covers for twin shock 125 and 250. Mike Ward [email protected]
Offline paul
« Reply #6 on: July 15, 2009, 11:17:30 am »
Hi Paul,
I think we spoke yesterday,i have asked the question to the factory, so
I will see how we go.
Best Regards, Chris
Chris Doves - Spare Parts Manager
Paul Feeney Group
PO Box 2492 - Nerang BC QLD 4211 - AUSTRALIA
Phone +61 7 5596 9009 - Fax +61 7 5596 6661
Australian Distributor for Husqvarna, MV Agusta & Cagiva Motorcycles
www.husqvarnamotorcycles.com.au   www.mvagusta.com.au
www.cagiva.com.au
This email transmission is for the intended addressee and is
confidential information. If you have received this transmission in
error, please delete it and notify the sender. The contents of this
email are the opinion of the writer only and are not endorsed by the
Paul Feeney Group Pty Ltd unless expressly stated otherwise.
Offline AJ
« Reply #7 on: July 15, 2009, 05:15:13 pm »
Paul,
Thanks for the Leads. I've sent an email to Mike Ward.
How do I contact Robert at Husky Rider.
regards,
AJ
Offline paul
« Reply #8 on: July 15, 2009, 08:14:12 pm »
Paul
Unfortunately there were no oversize pistons for this model and even the
standard one is no longer available.
Even the piston ring is no longer available.
Sorry..........
HUSKY SPORT - UK Distributor for Husqvarna Motorcycles
Mike Carter - Managing Director
The Green, Cheriton, Hampshire SO24 0QA
Phone +44 (0) 1962 771122 Fax +44 (0) 1962 771188
[email protected]   www.huskysport.co.uk
Offline paul
« Reply #9 on: July 15, 2009, 08:18:28 pm »
need dimetions may be able to match one up----
To: Paul Stacker
Sent: Tuesday, July 14, 2009 10:37 PM
Subject: PAUL
WERE WOULD YOU GET A PISTON FOR THIS
Offline AJ
« Reply #10 on: July 15, 2009, 10:33:06 pm »
Paul,
Thanks for the effort. You have achieved more responses in one day than I have in months of searching.
I have seen many restored bikes from all years displayed on this site. This gave me confidence in finding those rare pieces to finish your project.
I knew the piston would be a problem, but didn't think it would be a project stopper.
regards,
AJ
Do we try
Offline paul
« Reply #11 on: July 16, 2009, 03:39:05 am »
heres another aj try them too
http://mitomondo.co.uk/main.html
« Reply #12 on: July 16, 2009, 08:49:43 am »
Post up.
Bore size
Overall length
Gudgeon pin size
Compression height(top of pin bore to timing edge)
If piston is domed or flat
Number of rings
If there are ports or cut aways
I'll look in my chart for a suitable replacement (which there will be) I'm imagining the bore around the 64-66mm range which would make a few pistons viable.
Offline k2000x
« Reply #13 on: July 16, 2009, 03:33:03 pm »
hi if you still have the piston you can get them ceremic coated at high performance coating this can be used to take up piston clearance then they coat it with a teflon like finish mate ive had a few montesa ones done beautiful workman ship and cost me about $80 then jp pistons can make you your rings about $50 last set i got
Offline AJ
« Reply #14 on: July 16, 2009, 08:03:01 pm »
Thanks everyone for the leads.
Mike Ward is supplying me with a NOS kit.
The ceramic coating is an interesting solution I haven't heard of.
How does it go with a Nikosil/Chrome bore.
The contact for reproduction rings will be handy to keep it fresh.
Thanks again,
AJ
