Author Topic: Head gasket material  (Read 3687 times)
Offline vmxrider
« on: July 13, 2009, 02:49:52 pm »
I need a head gasket for my big bore XL 250 project, where in Sydney can I get a copper gasket made (I can supply a Cad drawing) or who supplies copper sheet so I can make my own. I've heard that aluminium has also been used for head gaskets, and I can't see why it wouldn't work and would be a lot easier to source.
Re: Head gasket material
« Reply #1 on: July 13, 2009, 04:16:26 pm »
A hole punch - pair of snips - some heat ...... sheet copper available at most Bunning outlets
Offline vmxrider
« Reply #2 on: July 13, 2009, 04:26:27 pm »
Thanks I'll check out Bunnings on way home tonight.
Offline vmxrider
« Reply #3 on: December 03, 2015, 09:18:30 pm »
Its only been about 6 years but finally getting the Motosport 270cc underway.
Got some 2mm copper sheet from a company I worked for and more or less cut a head gasket out by hand, not so pretty but should function I hope. Annealed it before fitting.
Should have I all back together and in bike next day or so and looking forward to having a bit more grunt. Motor has 130,000k's on it and was still on original bore, albeit with a broken 2nd ring.
« Last Edit: December 03, 2015, 09:20:37 pm by vmxrider »
« Reply #4 on: December 03, 2015, 09:29:53 pm »
Bunnings must be along way from home if it took 6 years  ;)
i though taking a few weeks to doing an airfilter was a long time.
Offline vmxrider
« Reply #5 on: December 03, 2015, 10:57:25 pm »
Did I say I'd have it all back together in the next day or so, oops, meant next decade or so.
Offline vmxrider
« Reply #6 on: December 04, 2015, 08:13:44 pm »
So all back together, clocked up about 20k's on the road so far, no sign of leakage. :)
Couldn't resist a bit of dirt as well.  :D
