Author Topic: 1975 DT125 or not?  (Read 7435 times)
walloway
1975 DT125 or not?
« on: June 01, 2009, 05:52:31 pm »
Has anyone got a clue what this is. Eng and frame number say it is a 10/75 DT125,  578-000158.
Certainly doesn't look like a DT. It has xt/tt500 shocks at the rear and a Honda front end. Foot pegs are welded to the frame and all welding looks "factory" quality, especially shock mounts. Any ideas?
« Last Edit: June 01, 2009, 06:03:04 pm by walloway »
DR
Re: 1975 DT125 or not?
« Reply #1 on: June 01, 2009, 07:07:05 pm »
the upper shock mounts and swingarm don't look original to me but I'll leave it to the darkside experts ;) maybe the frame was cut and the whole rear upright/subframe and mounts rewelded in a section. Any other welds to be seen that may indicate a cut'n'shut? Looks very much like my old DT/MX175 I had many moons ago!
« Reply #2 on: June 01, 2009, 09:42:19 pm »
It looks like a DT with a fairly ordinary LTR conversion done, although the rear frame loop looks far better than most hack-jobs.
The rare MX125C is similar to this bike, but the upper shock mounts are lower/further foward, and they run the YZ125C style motor (no auto-lube, painted black, bigger fins etc). The MX-C also has alloy rims, and non-cross-over exhaust, plastic airbox, etc.
The plastic side cover is probably YZ125C.
Other clues would relate to seat mounts (hinged or bolt-on), steering lock, exhaust mount near carby, and blinker mounts.
A pic of the rear brake pedal and footpeg would also help.
« Last Edit: June 01, 2009, 09:46:35 pm by Nathan S »
« Reply #3 on: June 01, 2009, 10:12:40 pm »
Hmmm... upon further inspection, it looks like it might have a MX/YZ-A barrel.
Is there a port for the oil injection?
What's the spacing of the intake boot/reed block bolts?
What's the prefix cast into the barrel (either on the side of the intake, or just above the base gasket).
walloway
« Reply #4 on: June 02, 2009, 12:06:08 am »
 Thanks for the interest. Part of the mystery is solved , it has a 175cc barrel ,prefix 45500, on it. Oil injection port ,yes. Reedblock bolt centre's are 55mm and 48mm approx. Engine appears to have been black earlier on.
walloway
« Reply #5 on: June 02, 2009, 12:09:06 am »
One more shot of the shock mount.
Offline frostype400
« Reply #6 on: June 02, 2009, 12:15:45 am »
interesting machine welds look good dont think factory some factory welds are terrible i wonder how the bike would go some one has spent a bit of time and money to do that thanks Michael. :)
1971 tm400 and PE's
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #7 on: June 02, 2009, 12:33:55 am »
i'm going to go out on a limb here and say the frame is the real deal MX125c,
the airbox is a good clue as it looks to fit well and be of an MX type design,
swing~arm and shocks look MX125c,
the wheels look to be DT with the steel rims,
Barrel is MX175 a/b if it's 455 prefix,
Head looks to be DT {low compression},
Pipe is definately DT, yukky poo......,
578 prefix shows DT125,
565 prefix is MX125c,
but, a 570 prefix should be an MX175c. which i've never heard of.
but should you be interested in selling this beast and live near Brisbane, i'd be interested. ;D
cheers.
« Last Edit: June 02, 2009, 01:03:41 am by vandy010 »
"flat bickie"
« Reply #8 on: June 02, 2009, 07:39:44 am »
Now that we've got the extra pics, I reckon I agree with Vandy - the frame, shocks, brake pedal and foot-pegs are MX125C.
Although virtually everything else seems to be DT or MX-A, rather than MX-C.
Shame that its been so butchered, but I want it too (and I don't care whether you live near Brisbane or not...;D ).
walloway
« Reply #9 on: June 02, 2009, 08:39:41 am »
a few more shots.
Motor turns over with plenty of compression and feels smooth, will take head off for an inspection.
Would possibly be interested in selling /trading , need cash or parts to finish off a B50MX/Triumph.
walloway
« Reply #10 on: June 02, 2009, 08:45:39 am »
try again
walloway
« Reply #11 on: June 02, 2009, 08:48:25 am »
The other bitza I need a few bits for .
Offline frostype400
« Reply #12 on: June 02, 2009, 09:11:10 am »
i wouldnt call the triumph a bitsa looks fairly complete thanks Michael. :)
1971 tm400 and PE's
« Reply #13 on: June 02, 2009, 09:36:06 am »
frosty look closer for race tape holding on front guards  ;)
« Reply #14 on: June 02, 2009, 09:38:25 am »
pps .. i have 175 leading forks in the YZ to swap for them under forks if your interested.  call goes out to anyone actually
