Author Topic: cz electrics  (Read 6072 times)
TREV53
cz electrics
« on: May 29, 2009, 08:15:24 pm »
has aneyone heard ct 180 i think replacing cz electrics ?
Offline Noel
Re: cz electrics
« Reply #1 on: May 29, 2009, 08:40:13 pm »
I seem to remember some one told me
TS or ER 185 Suzuki worked,
Noel
Offline k2000x
Re: cz electrics
« Reply #2 on: May 30, 2009, 09:54:36 am »
yep er185 electrics do work but you need to recut the taper on the flywheel to suit the cz crank
Offline HL400
Re: cz electrics
« Reply #3 on: May 30, 2009, 05:05:46 pm »
Hi Trev53, I am still using points in my cz, they are a pain in the LEG !!! when starting it but from what I have read you have a little more power.  H
Re: cz electrics
« Reply #4 on: May 30, 2009, 07:20:30 pm »
trev
how is it a pain in the leg.
my cr 250 elsinore has points and is fairly easy to start,on the other hand if the timing is not 100% correct it wil be a bitch of a thing to start just like my 360 yamaha with cdi ignition.have you thought of running 1 plug and a decompresser to make it easy to start.i am building a yellow tank cz400 and at this stage it will have points as i want the heavy flywheel efect.i also have a tt500 hagon yamaha 11.1 comp running methenol it has the decompressor and points,easy as to start,goes too fast for me to ride it at its full potencial
jim
cz250
cz400 both restos
Re: cz electrics
« Reply #5 on: June 02, 2009, 06:39:53 pm »
RM A model is meant to fit
Cant say what needed to be done
090
Re: cz electrics
« Reply #6 on: June 03, 2009, 05:35:29 am »
I went electronic after i was having issues with the points system. It is common for the windings to come loose . My bike was hard to start and was failing during riding.
I noticed the difference in power and ease of starting.
I just put my hand in my pocket and bought one from Les at mainly Maico.
