Author Topic: crankcase joint sealant recomendations  (Read 6842 times)
geoff22
Re: crankcase joint sealant recomendations
« Reply #15 on: May 27, 2009, 10:23:16 pm »
yes torm92 - my crank guy has done all my cranks this way for years and I have never had a problem with any of them
« Reply #16 on: May 27, 2009, 10:25:12 pm »
I do the centres of twins first, then treat each end as a single,if that makes any sense.I usualy stop at 2 thou as I've found it's easier to go backwards at that point.So I'll take any tips  ;D I use 2 dials also have a series(well 2 actually) guides to push the crank pin into the first half.That sees to get the pin a bit straighter, then into the press jig.I've found going together bit by bit and aligning as I go a bit easier than when it's completely together?????
