Author Topic: yz125 pistons  (Read 2495 times)
yz125 pistons
« on: May 25, 2009, 07:10:08 pm »
will a 85 yz125 piston go into a yz125e 78 model? they both share the same bore/stroke and piston pin so does anyone know or tried this combo?
TT5 Matt
Offline caps 999
Re: yz125 pistons
« Reply #1 on: May 25, 2009, 07:42:40 pm »
dont know about that one it think 76-82 intechange but later i dont know
MUGEN power
Re: yz125 pistons
« Reply #2 on: May 25, 2009, 08:58:12 pm »
Yes, it will work.
Yamaha has a squillion different part numbers because they were forever tweaking stuff like the number and thickness of rings and the skirt cut-away, but the pistons are 100% interchangable. They will all also interchange with DT and IT125 pistons.
I know that Wiseco has a different part number for the 85 compared to the earlier bikes, but I can't spot the difference.
The YZ-A piston kits have a different part number because they use a different ring to suit the chrome bore. The piston itself is 100% interchangable.
Offline oldyzman
  • 250 two stroke!
Re: yz125 pistons
« Reply #3 on: May 25, 2009, 09:25:39 pm »
hey nathan, is the skirt the same.  ie to give the same port timing on inlet..
Brett
