Author Topic: Maico Front Brake  (Read 24663 times)
Offline 2 shocks
  • Gods Country !!
Maico Front Brake
« on: May 24, 2009, 02:36:26 pm »
Does anyone have any information about adapting Yamaha front drum brake to a 81 490  ???
Mr Maico #54
Re: Maico Front Brake
« Reply #1 on: May 24, 2009, 02:49:00 pm »
G'day Mr Maico,
hope all is well. this topic came up some time back on the forum, and if i remember correctly Firko had some info, perhaps a PM to him will help you.
Regards
Hoony
Offline paul
« Reply #2 on: May 24, 2009, 02:55:40 pm »
i bought this bike ages ago and traded some off it to dave mac (includeing the reed barrell)  hind sight is a wonderfull thing  ::)
im not sure if it had a yamaha or ktm front wheel but it also had a square alloy lug welded up the inside of the fork to hold the backing plate in place .the wheel seemed to fit in there nicely
« Last Edit: May 24, 2009, 02:58:04 pm by paul »
« Reply #3 on: May 24, 2009, 03:16:59 pm »
I replaced a complete front end with a yamaha unit, but had to have triple clamps reamed out 1/2 mm to allow 43mm forks.
Pauls way looks cheaper and easier.....you just have to work out how to do it ;)
« Reply #4 on: May 24, 2009, 03:23:39 pm »
I did the same and fitted the yamaha forks and wheel by machining out the triple clamps. Was very easy but i'd probably have preferred to keep the maico forks if i did it again.
Offline holeshot buddy
  • sunshine coast qld
« Reply #5 on: May 24, 2009, 05:10:00 pm »
i thought maicos were good
do they have a shite front brake ;D ;D ::)
follow me to first turn
« Reply #6 on: May 24, 2009, 05:35:57 pm »
Only to even things up a little cos they are so much better than the rest of the field.
« Last Edit: May 24, 2009, 05:43:08 pm by JohnnyO »
Offline maicomc490t
« Reply #7 on: May 24, 2009, 07:36:11 pm »
YZ465 TLS from '80 or '81 will do the trick but a slightly complex looking plate has to be fabricated with a lug to engage the brake plate and extend up the fork leg to be secured by he usual front brake stay mounting lug. Not too hard at all.
The front end I got from Paul included a lug welded to the LH slider a la most Jap bikes to mate up with the KTM? (from memory) TLS - all very neat and destined for a bike I want to build for my young bloke but he will have to settle for the superb? Maico stopper first (he figures cornering speed will be sensational, lol!
Les Richters can also supply on exchange brake shoes lined with some sort of fiction material usually reserved for the brakes on roller-coasters or some such thing.
Boring out the triples is no big deal if required just a bit of a fiddle required although the amount removed from the bores will be on my measurement be 1.3mm as the Maico staunchions are 41.7mm.
In the next week or so I'll try and remember to dig out the bits of both the 465 option along with the other I mentioned and make more sense of it plus take some pics.
Work in progress
Dave Mac
BULTACO M49 parts wanted
« Reply #8 on: May 24, 2009, 07:44:10 pm »
Dave did welding a lug on the lower fork leg distort the leg in any way? Does the fork staunchion still slide in and out freely? I've often wondered if this is the best way for the yamaha wheel conversion opposed to making a bracket with a lug attatched to it like they did back then.
Offline maicomc490t
« Reply #9 on: May 24, 2009, 08:12:28 pm »
Johnny O - I'll check it all out and report back but from memory all seemed pretty good but care and a good welder would have to be applied that's for sure !
Dave Mac
« Reply #10 on: May 24, 2009, 09:03:09 pm »
Dave,
The clamps only require a bit over 1/2 a mill taken out to get the required 43mm dia.
« Reply #11 on: May 24, 2009, 09:32:08 pm »
Yeah .65mm on either side or 1.3 in total. You can hardly notice the difference once it's done.
« Reply #12 on: May 24, 2009, 09:51:49 pm »
what sort of front rim is that on those photos Paul?
Here is a KTM plate
« Last Edit: May 24, 2009, 09:55:38 pm by LWC3077 »
Offline frostype400
« Reply #13 on: May 24, 2009, 09:58:01 pm »
Hey i reckon your spot on there Leith it looks to say the same on Pauls plate  :)
1971 tm400 and PE's
« Reply #14 on: May 24, 2009, 10:13:44 pm »
That ktm backing plate looks like it has 2 locating slots for the lug on the fork leg. It does look the same as the one on pauls bike.
