Author Topic: Sprockets ?  (Read 3810 times)
Sprockets ?
« on: October 05, 2007, 12:44:26 pm »
what are you MXA guys using for sprockets or where are you getting them from.
the rear has a HOle Diamter of about 92mm and im struggling to even find a blank that i can drill carier holes in ?
or have you changed the rear wheel to a DT ot TT ?
Whats the secret squirrel info here ?   ???
Re: Sprockets ?
« Reply #1 on: October 05, 2007, 09:50:24 pm »
Have you tried John Titman Racing they have or machine plenty of blanks up.Then just drill the holes on the correct PCD and enlarge the centre hole,beware the blanks are about $80(in ali)
Re: Sprockets ?
« Reply #2 on: October 06, 2007, 02:58:48 pm »
are there cheaper options ? the only thing i can find with that 92mm centre is a ktm but its a 120pitch.   Surely someone has replaced sprockets in the last 5 years ?????
Re: Sprockets ?
« Reply #3 on: October 06, 2007, 03:44:18 pm »
Ebay USA. They're listed every other week. I've bought two in the last year. You're not really trying too hard Freak ::). This shit is common as.....Here's one picked at random  http://cgi.ebay.com/ebaymotors/Yamaha-DT-250-MX-250-360-Rear-Aluminum-Sprocket_W0QQitemZ200147133879QQihZ010QQcategoryZ10066QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
« Last Edit: October 06, 2007, 03:49:53 pm by firko »
Re: Sprockets ?
« Reply #4 on: October 06, 2007, 08:42:59 pm »
Yep got you on that firko  ;)  but, i was hoping somthing as simple as that was a local thing and about $40 bucks ?  ::)   having to get sprokets from OS seems a bit crazy unless they where cheap @ $30 a set plus postage ? >:(
« Last Edit: October 06, 2007, 08:46:29 pm by Freakshow »
