Author Topic: save weight xl.  (Read 3114 times)
Offline hampster
save weight xl.
« on: April 30, 2009, 04:44:55 pm »
Hi,
Trying to cut some weight on an xl 350.
Looking at the back wheel, does a tl 250 or mt 250 fit/work?
I know a sl 350 works and is 2 kgs lighter but vary hard to find.
Chris.
worms
Re: save weight xl.
« Reply #1 on: April 30, 2009, 05:52:24 pm »
small tip , lose wieght by going to gym ;D
mx250
Re: save weight xl.
« Reply #2 on: April 30, 2009, 06:17:04 pm »
A hampster that needs to lose weight :o :o :o :o
Offline hampster
Re: save weight xl.
« Reply #3 on: April 30, 2009, 07:48:01 pm »
Looks like you cracked the master plan if i can save 10 kgs off the xl i will never have to go to gym.
Offline gorby
Re: save weight xl.
« Reply #4 on: April 30, 2009, 10:09:21 pm »
MT250 hub is the same item excepting it runs 520 sprocket v the 530 size on the XL
the MT has a steel rim v the alloy one on the xl
Offline hampster
Re: save weight xl.
« Reply #5 on: May 01, 2009, 07:41:39 pm »
hi,
would an sl 125 wheel work, has a cush drive just need to set up a sprocket its a lot lighter just relace the rim with an
alloy one with the right off sets and space in the swing arm.
Chris
Offline gorby
Re: save weight xl.
« Reply #6 on: May 01, 2009, 09:27:05 pm »
the four post cush drive would only barely take the power ??? of the 125.
one good squirt of the throttle or a throttle on landing would shear them off and instant nuetral :o
stick with the original and save your gearbox,you can save considerable weight by using a sensible sized tyre.
