Author Topic: cz 250 big end bearing  (Read 4659 times)
Offline k2000x
« on: April 20, 2009, 03:32:29 pm »
does anyone sell big end bearings 4 a cz250 in australia
Offline Bamford#69
Re: cz 250 big end bearing
« Reply #1 on: April 20, 2009, 05:06:50 pm »
Hi ,
If dont replace the big end bearing ,con rod,and crankpin as an assembly   you  will be sorry.
Good Luck,
Offline k2000x
« Reply #2 on: April 21, 2009, 10:15:40 am »
you could once get an i.n.a bearing that you could use if there were no marks in the rod
Offline k2000x
« Reply #3 on: April 21, 2009, 10:17:07 am »
im new 2 cz stuff it has no up and down movement but there is plenty of side 2 side is this normal
Offline Bamford#69
« Reply #4 on: April 21, 2009, 01:07:01 pm »
Hi
the reason there is side freeplay in the big end,(in a good motor), is because there are no  thrust washers in the bottom end , that is why they have the thrust washers on the gudgeon pin , do not use any thing other than the factory thrust washers up there, remember, any thing made out of steel in a CZ mxer is made out of recycled Kalashnikovs and T18 tanks, including mud guards,fuel tanks and air boxes, strong but really heavy.
If you read a CZmxer parts book, page 14, you will see there are 4 size of big end bearings to match up with 5 fractional fit con rods .
Good Luck trying to save a buck.
« Reply #5 on: April 21, 2009, 02:08:17 pm »
Plenty of engines run fine with no piston thrust washers, and converting to big end thrusts is a doddle. Have you got the gudgeon pin dia, centre to centre length, crank pin dai and width and I'll look in my charts and see if there is an alternate rod.
« Reply #6 on: April 21, 2009, 05:36:40 pm »
Why bother. They are over the counter stuff as they are pretty much the same thing all the way through. I think a rod kit is about $250. Les at Mainly Maico sells them.
« Reply #7 on: April 21, 2009, 05:54:08 pm »
About $120 less bother ;) or the CZ rod kits must come hand delivered , individualy wrapped and boxed in Channel No5 boxes  ???
« Last Edit: April 22, 2009, 10:45:17 am by Lozza »
