Author Topic: RM125X vs RM125Z CDI & Coil  (Read 2824 times)
Offline Tex
« on: April 17, 2009, 10:15:12 pm »
Does anyone know if a CDI & coil combo from an RM125X will work ok on a RM125Z?
They are physically different, but I wonder if there is any actual difference in performance.
Any insight appreciated.
RMJJ
Re: RM125X vs RM125Z CDI & Coil
« Reply #1 on: April 24, 2009, 01:46:39 am »
Yeah they will work no problem whatsoever. There is no difference in performance at all.
The coils are different sizes and the X has an earth wire. You just need to earth that wire and adapt the frame bracket to accept the larger X coil.
and you will need to make a bracket to bolt the X cdi to.
its all an easy job.
« Last Edit: April 24, 2009, 01:49:00 am by RMJJ »
Offline Tex
« Reply #2 on: April 24, 2009, 09:51:08 pm »
Thanks RMJJ, much appreciated!
That's good news as I have a Z CDI but all the wires have been butchered.
I only have a spare PE175N coil at the moment, do you think this combo would work ok with the X CDI 'til I find an RM125X coil? It looks the same as the RM125 unit and all the wires match up nicely.
It seems to create spark ok too...
RMJJ
« Reply #3 on: April 25, 2009, 07:03:58 pm »
Yeah its the same coil for the PE and RM of those years same part number.
Offline Tex
« Reply #4 on: April 27, 2009, 10:43:08 am »
Coil is actually from a 1979 PE175, but I'd assume it'd be more or less the same?
Thanks for all the advice, I owe you a beer!
RMJJ
« Reply #5 on: April 27, 2009, 07:32:09 pm »
Yeah thats what I meant by those years. 1979 PE and 1981 RM
both use the same coil.  ;D
