Author Topic: Starting rollers  (Read 20673 times)
Offline ksithumper
Re: Starting rollers
« Reply #45 on: June 03, 2013, 04:27:29 pm »
Rollers, especially the small diameter ones, work fine on road tyres but are hopeless when trying to grip a wet muddy knobbly.
The us flat track boys use plug in hand held starters, they work a treat and can be taken to the start line so you don,t have to leave your bike ticking over and getting baking hot while waiting for the previous race to clear the track.
Search the ads on vft.org and you will find plenty.
CCms are usually pigs to start, mainly cos the kickstart is low geared and short. Mine also needs a different tickover setting hot vs cold. Xl350s are prone to breaking a tooth on the idler gear should it kick back, that idler drives the oil pump so it gets very  very expensive, fast. Don't ask how I know. I've now removed the kicker, and temptation!
Offline Rookie#1
  • JUST SHUDDUP AND RIDE IT!!!
« Reply #46 on: June 03, 2013, 05:02:06 pm »
Might be a dumb question but would adhering some hardy rubber linings to the steel rollers be any sort of remedy for this?  :-\
« Reply #47 on: June 03, 2013, 05:39:13 pm »
The rollers on the roller picture posted today has roughed metal and the tubing also fits between the knobs.  8) Got confirmation that this roller started many bikes at Dandaloo Classic and he should of been charging $$  ;D
« Last Edit: June 05, 2013, 07:50:21 pm by VMX247 »
« Reply #48 on: June 05, 2013, 06:54:29 pm »
its a "knobby" tyre isn't it?? Knobbly is what knees end up like ???
Offline ksithumper
« Reply #49 on: June 06, 2013, 02:31:18 am »
Knobbly in the UK, knobby in the US.
I have absolutely no idea what it is in Oz...
« Reply #50 on: June 06, 2013, 07:11:29 pm »
same as the yanks
Offline SlideRulz
  • Not anti social just anti idiot.
« Reply #51 on: June 06, 2013, 07:24:20 pm »
Yeah same as the Yanks.
A friend of mine bought out a set of road racing rollers to start his big bore Mettise which had a DT trials tyre on the rear.
Tyre shredded and still no noise, rollers worked perfectly on his Road Racing tackle the week before.
Not one set up will suit all.
Offline Slider29
« Reply #52 on: June 06, 2013, 07:55:14 pm »
 I've seen one that uses a Briggs and Stratton motor or similar and the roller is a go-cart wheel. Works a treat on speedway bikes
