Author Topic: Eligilibty scrutineer at the Nationals  (Read 118521 times)
Re: Eligilibty scrutineer at the Nationals
« Reply #30 on: March 22, 2009, 06:42:10 pm »
i cant see what the reasons are for not allowing someone to race a pre 75 bike in the pre 78 class if they want to as they would be at a disadvantage anyway so why not just allow that?
« Last Edit: March 22, 2009, 07:03:18 pm by LWC3077 »
Offline mboddy
  • Canberra
« Reply #31 on: March 22, 2009, 06:47:06 pm »
Do others agree that as flat slides (to the best of my knowledge) were available in 77 therefore they should be legal post 75 classes??
Hi Dave. I am Mark Boddy. We met at the 2008 Classic Dirt Track Nationals and I was one of the Scrutineers.
I was PCRA's eligibility guy for New Era from it's establishment through to the end of 2007.
I was coached by Marcus deCaux on eligibility issues and have been involved in some eligibility disputes at National open meetings.
I have successfully protested a bike on eligibility grounds.
Historic Road Racing rules consider the Carburetor to be a major componant and therefore it must be of the same Era of the bike.
Why should Classic MX and Dirt Track be any different?
The original intent of the flat slide rule can be determined from past versions of the MoMs. (In 1977 Pre-75 was the newest class).
For example,
Quote from: 1997MoMs
16.11.4 b) Carburetors
i) Any round-slide carburetor can be used.
ii) Modern flat-slide carburetors are prohibited.
iii) Early flat-slide carburetors (Walbro, Lectron etc.) are allowed provided the owner can prove that they were available pre 1975.
What happened was that it was not possible to prove that the Lectron was available pre 1975 because it was not available until 1976.
So the rule was changed.
In 2000 Pre-75 was still the newest class and the rule was:
Quote from: 2000MoMs
14.2.6.2 Carburettors
a) Any round slide carburettor of a type manufactured within the period specified for the class in which the machine competes. For Pre 1960, 1965 classes the Mk 1 Amal Concentric may be used.
b) Flat slide carburettors are prohibited.
c) No reed valves ... etc
d) From 01/01/2001 no reed valve ... etc
For 2002 Pre-78 was added to the MoMs. But only the most minimal changes were made to the Classic Motocross rules to incorporate it.
This is the root of the problem.
The carburettor rule was updated again:
Quote from: 2002MoMs
a) Any round slide carburettor of a type available Pre 1975 may be used except the Pre 1960 class where a Mk 1 Amal Concentric or period carburettor may be used.
It seems to me that the change to the carburettor rule was made independently to the addition of Pre-78.
What other reason would there be to exclude round slide carbys from 1976 or 1977 from Pre-78 bikes?
The general precedent of rules in the MoMs is that Era parts are allowable in the Era. This oversight is inconsistent with this.
For the next year (2003) a serious attempt was made to add Pre-78 to the MoMs.
Pre-78 was given it's own eligibility section:
Quote from: 2003MoMs
14.2.13 Pre 78 Classes and Eligibility
These detailed rules contradicted many rules that appeared before them in the MoMs. For example, 7" suspension travel limits, etc.
It is clear when reading the 2003 MoMs that these rules applied to Pre-75 and 14.2.13 applied to Pre-78.
This should probably have been explicity stated in the MoMs but was not.
Later Evo and Pre-85 were added each with their own Eligibility section.
If you do not believe that this is the intention of the rules then how do you explain the rationale for a pre-75 roundslide Mikuni to be fitted to a 1980 IT175G before it is allowed to race (it had a 32mm powerjet Mikuni) or to have to fit a Mikuni roundslide to a Pre-85 RM Suzuki to replace their Mikuni TM?
This is obviously nonsense.
So what carbies can be used?
This is a list of some common carbies and their availability date:
Lectron (non powerjet) 1976
Lectron powerjet 1979
Mikuni powerjet (roundslide) 1979
Mikuni TM 1982
Keihin PJ 1985
Mikuni TMX 1987
Keihin PWK 1988
Mikuni TMS 1992
Mikuni PM 1998
Keihin PWM 1999
Therefore as the flatslide Mikuni was not available in 1977 it cannot be used in Pre-78.
The MoMs should NOT be amended 'to allow flat slides for Pre-78 and later'.
Instead it should be amended to explicitly state that all eligibilty for Pre-78, Evo and Pre-85 classes is stated in the individual section for each of these classes.
Mark Boddy
« Last Edit: March 22, 2009, 07:39:48 pm by mboddy »
Vinduro Penrite Team
worms
« Reply #32 on: March 22, 2009, 07:03:36 pm »
i will jump in say 2 things, first you are right about flat slides for pre 78 Mark and on the question of riding up a class, which is why, when pre 75 has a majority of classes available to it and when you bring pre 85 into the ? where can they ride up to, also with an expected 300 competitors for this event, instead of pushing the rules and say why cant i, i think it comes down to the fact that all bikes race under there own class, isnt that what classic motocross is about, otherwise, we would have all in races with whatever bike you wanted to ride. And then there
would be the ? why cant i ride down? ;D
Cheers Trev
« Reply #33 on: March 22, 2009, 07:21:10 pm »
didnt the mikuni flatslide TM come out on some of the 82 model bikes? I think this discussion is good and it is what is needed and so many people have questions as to what is legal and what isnt, so the more questions asked here the better i say, and by the time the races come around everyone should be educated and up to speed on whats allowed and whats not.
« Last Edit: March 22, 2009, 07:26:19 pm by LWC3077 »
« Reply #34 on: March 22, 2009, 07:29:52 pm »
Trev - the question was riding up A class or period?  Don't colour the issue by asking about riding "back" a class?  Somewhere over the last "few" years this has been disallowed - the question was why - thats all. Also for clarification - one period or class was what I was used to ie no 125s in 500s therefore pre 75 in pre 78 - no more no less.  I also thought pre 78 was a bit of a forgotten class and maybe numbers might not be so forthcoming?  Also it doen't matter how many classes before per 75 - I was refering to per 75 only.
regards
Rossco
Offline mboddy
  • Canberra
« Reply #35 on: March 22, 2009, 07:31:12 pm »
I believe that it was 1983 based on my research. But if you know of any 1982 models then I would be keen to know which ones.
« Reply #36 on: March 22, 2009, 07:34:12 pm »
1982 Suzuki RM 250 Z had a flat slide carby - couldn't say which one at the moment - not at home.
Rossco
Offline mboddy
  • Canberra
« Reply #37 on: March 22, 2009, 07:39:21 pm »
I just checked the online Suzuki parts catalog and you are correct. It is a Mikuni TM. I'll update my previous post. Thanks.
« Reply #38 on: March 22, 2009, 07:41:03 pm »
thought so. It would be the TM then. So does that mean you can buy a new aftermarket TM mikuni and fit it to another 82 suzuki that didnt have a TM flatlside but since they were on the 82 RM250 it makes it allowable?
Offline mboddy
  • Canberra
« Reply #39 on: March 22, 2009, 07:44:11 pm »
For Pre-85 you can.
Evo may be a different matter because of the undefined 'OEM' statement.
Anyone got a good definition for OEM to add to the Evo rules?
090
« Reply #40 on: March 22, 2009, 08:21:55 pm »
Riding "up" a class , either bigger capacity or later era can't be supported and i would say it wont. Its a national title , not a club day to start with. Also if you had 20 guys with one bike wanting more rides, that would be chaos for riders and officials. At the end of the day, its not in the spirit of the ERA. It is the one event where you have to dot your I's and cross your T's, by the book.
« Reply #41 on: March 22, 2009, 08:29:12 pm »
ok i understand that now. I was just wondering why and didnt know the reason.
« Last Edit: March 22, 2009, 08:36:23 pm by LWC3077 »
« Reply #42 on: March 22, 2009, 08:29:51 pm »
YES 090 agree - I'm really feeling for the rider....
who has done X amount of rides
who is not reading this forum chat or a MOM's.
who has used  X amount of these carby's,
too do X amount of km's to arrive at a nationals,
to only be told in X amount of terms.......NO GO ......
Alison
« Last Edit: March 22, 2009, 08:31:57 pm by vmx247 »
Rosco400
« Reply #43 on: March 22, 2009, 08:40:45 pm »
Hi Dave
Piggy back shocks on 1977 AW400 Maico, yes or no as you rolled your eyes ::) at the DT nats, they were available in the era, and yeah i know the numbers have to be bigger and straight :D
Thanks Ross
« Last Edit: March 22, 2009, 08:46:45 pm by Rosco400 »
« Reply #44 on: March 22, 2009, 08:54:17 pm »
i thought the rule was no piggybacks or remote reservoirs on pre 78 bikes except for those Thermal Flow shocks.  or maybe im thinking of the pre 75 sidecar rules? hmm now that i think about it i have a sales brochure that says the Koni remote reservoir shocks were used in the 77 season by the top professional riders, so i wonder if they could or should be allowed? Also Fox had optional reservoir kits available before 78. But i guess if there is a rule that says NO to all reservoir shocks period or modern for pre 78 then thats the rule. Having just said that ive been told shocks are classed as consumables so anything goes? It gets so confusing!
« Last Edit: March 22, 2009, 09:11:36 pm by LWC3077 »
