Marque Remarks
Suzuki
TS185A BORE SIZE
Topic: TS185A BORE SIZE (Read 3431 times)
TT5 Matt
TS185A BORE SIZE
March 20, 2009, 09:37:19 pm »
hi all
does anyone know the std bore on the 185's,pulled the top off last night and tried a std set of rings i got off fleece bay down the bore and they had over 45 thou end gaps so now on the lookout for a .50mm oversize piston and rings if anyone has some for sale
TT5 Matt
Re: TS185A BORE SIZE
March 20, 2009, 10:00:05 pm »
64 mm std bore size Ts 185 1971- 1981
cyclegod
Sunny PERTH W.A
March 20, 2009, 10:07:41 pm »
http://cgi.ebay.com/ebaymotors/Suzuki-TS185-TC185-Piston-rings-set-Nos-Size0-50_W0QQcmdZViewItemQQcategoryZ10066QQihZ013QQitemZ230288969791QQrdZ1QQsspagenameZWDVW
Ban BLACK rims NOW
TT5 Matt
March 21, 2009, 12:20:15 am »
thanks for the information guys went down the shed and recleaned the top of the piston to see .50 on it and to much taper to not oversize it so does anyone have a 1mm piston kit for sale or maybe MR GOD can find one o to have city high speed broadband instead of 52k slow as band and the std rings are for sale $12 with post
TT5 Matt
LWC82PE
Superstar
Reply #4 on:
March 21, 2009, 12:42:00 am »
this ones a little on the expensive side i think. Check with the importer in QLD ( Serco) first to compare prices. TS 185's are one of the easiest bikes to get pistons for, so you shouldnt have a problem finding one. There are many brands that make aftermarket ones fo them.
http://cgi.ebay.com/ebaymotors/Suzuki-TC-TS-DS-185-71-80-040-Wiseco-176M06500-Piston_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem120384316752QQitemZ120384316752QQptZMotorcyclesQ5fPartsQ5fAccessories
this place also will have some, but i think you will have to go through a local dealer
http://www.bbimporters.com.au/
here is what you want. good price too
http://cgi.ebay.com/ebaymotors/Suzuki-TS185-TC185-Piston-rings-set-Nos-Size1-00_W0QQcmdZViewItemQQ_trksidZp3286Q2em20Q2el1116QQitemZ360086537686QQptZMotorcyclesQ5fPartsQ5fAccessories
Last Edit: March 21, 2009, 12:47:29 am by LWC3077
JC
Reply #5 on:
March 21, 2009, 09:11:55 am »
Mat,
Try satellite broadband. There's a Gov't subsidy if you can't get decent speed where you are, that makes it reasonable cost. I get mine for $22/mth. Much better than dial-up
ty4
A-Grade
Reply #6 on:
March 21, 2009, 06:56:38 pm »
Mat
have 2mm up Wiseco piston & rings plus 2mm up piston only if that helps?
possibly have some gaskets as well,not sure
Marque Remarks
Suzuki
TS185A BORE SIZE
