Author Topic: ts 400 1973 carby parts or complete or info on a conversion  (Read 1381 times)
lms6201
« on: March 06, 2009, 08:04:55 pm »
 i have a bloke here with a fully restored 400 but the carb nozzle and needle is worn beyound use , or it has been drilled , , we need the bits or if anyone has converted a vm 34 or something similar please advise the spec,s    [email protected]
Doc
Re: ts 400 1973 carby parts or complete or info on a conversion
« Reply #1 on: March 06, 2009, 09:24:02 pm »
I fitted an RM370 VM36 to my TS400 and while a bit doughy it ran pretty well. Oldfart then fitted a 'new' PE250T VM36, increased only the main slightly and it went like a cut snake in comparison. Can find out the main size but 310 rings a bell. The only thing is the RM370 and the RM400C 36mm carbs don't come fitted with an idle screw. I like the idea but on a trailie it'd be a right pain. PE250 carb could be the go but another wee problem maybe the inlet size for the rubber airbox boot.
lms6201
« Reply #2 on: March 06, 2009, 09:29:02 pm »
thnaks doc , i have a vm 36 from it 250 , if we could find out the jetting might be able to adapt
