Author Topic: Wisco piston that is round  (Read 7220 times)
Doc
Re: Wisco piston that is round
« Reply #15 on: March 04, 2009, 06:45:06 pm »
John, did it score the bore? Either way all is not lost. While 56mm is max for the 125BCNT it's std bore for TM/TC/TS/CR125's ;) you just need to do some ring locating pin relocating to stop it hanging up in the ports.
« Reply #16 on: March 04, 2009, 06:47:01 pm »
just something on that, when you re loate the pins, do you just drill a tiny hole and jam in the pin? how do you know the pin is going to stay in there and not work loose?
« Reply #17 on: March 04, 2009, 06:59:34 pm »
Having the ring between the ring peg and the bore helps, so does a good interference fit on the peg ::)
Offline asasin
« Reply #18 on: March 05, 2009, 12:03:14 pm »
Thanks Doc the RM S piston I have just replaced twigged me to that but it comes up 60 thou short in the barrel ,so would have to lathe 60 thou off bottom , may be a way out though.The rebuilder was helpfull after all and has re honed it for free and suggested I take a small "slice" off each side of the piston and try again. Interesting that my RM B book suggests 3 thou clearance weras Wisco reccomend 2 . i will give it a shape up and try again, then go the TM piston way
John
If in doubt ,WIND IT OUT
