Author Topic: 250 d chain tension fix  (Read 3681 times)
Offline hampster
« on: February 16, 2009, 02:33:09 pm »
Hi,
Seen the yz chain guild fix.
What do think would be a good set up for my 250 d?
At the moment i am running std set up with chain tension at rear and running over a fixed block at the pivit point, this looks like it could derail at any time.
Would a small wheel ran at the back engine plate spacer bolt position help?
thanks Chris.
Offline ARN
Re: 250 d chain tension fix
« Reply #1 on: February 16, 2009, 04:40:02 pm »
hi   i have removed the tensioner and been using ktm type sliders on the lower part of the swingarm in front of the sprocket .i also put a roller under the chain on the frame where the stand bracket came off. i have done this to 2 aluminium after market swingarms but it would be easeir to adapt to a metal swingarm       will try to get some pics up
Offline brent j
« Reply #2 on: February 16, 2009, 08:14:21 pm »
I fitted a roller to my mates YZ250D and he's very happy with it.
We welded a small lug to the frame so the roller sits below the swingarm pivot. With a spring loaded tensioner the chain is tight on the drive side but becomes loose on over run. With the roller, the tension stays constant.
He says the difference is noticable.
I can get a pic but it won't be before the weekend at best.
Brent
Offline hampster
« Reply #3 on: February 16, 2009, 08:42:51 pm »
Hi Brent,
did you use the rear engine plate lower spacer treaded section to fit the other end of the roller bolt?
Chris.
« Last Edit: February 17, 2009, 07:54:04 am by hampster »
Offline brent j
« Reply #4 on: February 18, 2009, 07:09:43 pm »
The bracket is on the plate that mounts the swingarm.
We never thought to look at the engine mount plate......................
« Last Edit: February 20, 2009, 12:50:16 am by brent j »
Offline holeshot buddy
  • sunshine coast qld
« Reply #5 on: February 19, 2009, 09:08:15 pm »
chris i put one of those spring tension adj jobbys
on my rm370 works great no problems 8)
mcs sell them at most bike shops about $35 bucks i think
bill might have one :o
when are you picking up cr250rc
saw it today nice bike ;D
follow me to first turn
Offline Husky500evo
« Reply #6 on: February 20, 2009, 09:06:32 am »
Or you could build something really different like one of these Luft hydraulic tensioners .
Offline hampster
« Reply #7 on: February 20, 2009, 05:24:52 pm »
Looked at fitting spring tension set up
have not found a spot on the frame to fit it ?
Mybe the hydraulic, does this pass pre 78?
Pick up the Cr next week ready for tambo.
Chris.
« Last Edit: February 20, 2009, 05:26:32 pm by hampster »
