Author Topic: Kickstarter shaft seal 1979-80 250  (Read 4600 times)
Offline Husabergpete
« on: February 02, 2009, 05:39:44 pm »
Gents,
Need help with getting a seal for the kickstarter shaft on this 250. The shaft is 17mm and the od of the caseing is 22mm. Seal place had nothing and my parts book only gives a 14mm shaft size same as the gear change.
Thanks Pete.
« Last Edit: February 16, 2009, 11:46:43 am by Husabergpete »
oz555ktm
Re: Kickstarter shaft seal 1979-80 250
« Reply #1 on: February 02, 2009, 09:15:38 pm »
G'Day
The Seal on a 55 or 54 engine is not a Seal but a O-ring
Part No 0770160030  use the number a a KTM shop????
you also need the bush as well Part No 550 33 0069 000
Or
you can go to a Auto shop and buy 2 o-ring 16 x 3 and fit the 2
o-ring side by side and push the Kickstarter on Hard .
you may need to push the  1st o-ring in with somthing to get it
and the 2nd will keep it in place .
« Last Edit: February 02, 2009, 09:18:04 pm by oz555ktm »
« Reply #2 on: February 02, 2009, 10:09:40 pm »
Dennis,
Thanks very much for the info. Adrian G has been a huge help with the rebuild so far. Motor back together and in the frame. Never worked on such a fiddlie bike. I can see where all the original costs in making these things went. Still plenty to do before Glenbawn Race Day. See you all there.
Pete
oz555ktm
« Reply #3 on: February 02, 2009, 10:35:51 pm »
You will allway find a help by any KTM Owners as weare all Family .
KTM Family that is ...
Offline ozktm
« Reply #4 on: February 13, 2009, 08:18:58 am »
Hey den,
i heard this thing fire to life last night for the first time......sounds sweet as. Peter has done a wonderful job of putting it together. just needs all the fiddly bits done and it will be ready to run at Gelnbawn.
Regards,
Adrian Goold #101
« Reply #5 on: February 16, 2009, 10:50:42 am »
Gents,
Thanks - two 16mm id x 3mm thick from SES bearing supplies and no leaks as yet.
Ta Pete
