Author Topic: simons udx forks  (Read 2665 times)
Offline caps 999
simons udx forks
« on: January 27, 2009, 03:11:45 pm »
does any one have any info on these and will they fit a cr480
MUGEN power
Offline Marc.com
Re: simons udx forks
« Reply #1 on: January 27, 2009, 03:29:51 pm »
Sure they will fit a CR480, last set I saw on ebay was USD $3200 so you will need a decent over draft or to very lucky at a swap meet/
Offline caps 999
« Reply #2 on: January 27, 2009, 03:55:48 pm »
im helping someone do a 480 and he found a set in oz lucky basterd he wanted to know if thell fit
MUGEN power
« Reply #3 on: January 27, 2009, 05:27:17 pm »
ask Thor Lawson here http://ltthor.home.comcast.net/~ltthor/forsale.html he will have info/parts/manuals etc
Offline Maicojames
« Reply #4 on: January 29, 2009, 02:31:54 pm »
Well, they wil fit. Since they were a universal aftermarket accessory-they will sureley fit almost any bike-and be usable on about any bike with the appropriate wheel travel design. The stem may or may not be the one you need, I would expect that one can be machined for less than sourcing one specific for you make and model. Also, you will likely need to fabricate a brake stay/and or cable guide depending uopn your setup. Of course, should the forks have been previuosly fitted to an era 81450,82-83 480, or 84 500 -I expect you may have the correct parts already.
« Last Edit: February 01, 2009, 10:38:12 am by Maicojames »
Life is suddenly very Monaro
