Author Topic: 2T oil  (Read 10516 times)
Offline pancho
Re: 2T oil
« Reply #15 on: January 29, 2009, 10:12:31 pm »
i have difficulty with the logic of the statement "the damage was caused by roller skid" & "lubricant to good" to me these two statements don't fit together. one would think if the rollers skid because the oil is to good that would indicate a lack of friction between the rollers and the other components. no friction means no metal to metal contact which is an essential component leading to early failure. [apart from the introduction of an abrasive or corrosive material.] can anyone fault my reasoning? cheers wally..... ps on the subject of hygroscopic oil anyone who has had water in their engine oil [eg blown head gasket] would eventually witness oil emulsifying wth the water.
Re: 2T oil
« Reply #16 on: January 29, 2009, 10:32:22 pm »
I love the quote "nobody ever killed an engine by using to much oil" .A big end failure could only be caused by maybe 3 things.1 No oil 2. Substandard rolling elements or cage 3. Excess rpm. Seen inside a few KTM 85's and they are a well designed engine and have 22mm crank pin on an 85 which is over engineered.
Re: 2T oil
« Reply #17 on: January 29, 2009, 10:36:09 pm »
oz555ktm castrol tts is not a mineral oil.you have it mixed up with castrol super tt which is.and ring castrol yourself and ask as i didabout it being hydroscopic.
Re: 2T oil
« Reply #18 on: January 29, 2009, 10:40:35 pm »
i knew of a guy who used castol TTS at 40 to 1 in a modern KTM 300. big carked it big time. was a costly repair.
