Author Topic: WP4054 Forks  (Read 20861 times)
Offline zorroz
Re: WP4054 Forks
« Reply #30 on: February 01, 2009, 11:02:45 pm »
Zorroz, the ones Bahnsey has are aftermarket  WP fork's specifically for that Husqvarna and not OEM and fitted to Husqvarna from the factory. That was good you could tell use what the numbers ment.
Thats interesting cause the forks on my WMX125 aren't the original either and the only difference in the number is mine have '48 86' stamped, built one month earlier. Mine must have been swapped over by someone in its life.
Offline Marc.com
Re: WP4054 Forks
« Reply #31 on: February 02, 2009, 10:19:53 am »
Thats AU$5000 Fark :o I am about to peel a set out of a box for my '80 CR/ME 125 , might be better off just flogging them ??? once they are bolted on they are never going to be NOS ever again  :-\
[/quote]
yep but they are not much use sitting in the box...... I would keep the packaging though  ;)
Re: WP4054 Forks
« Reply #32 on: February 10, 2009, 12:08:15 pm »
Banshy,
just took delivery of my '86 250 xc
Have checked the caliper measurements and the mounts on it are only 60mm center to center, it runs a single piston brembo unit, I don't know if husky went to a dual piston set up on the cr's in '87/'88 or not, that's one for the husky anoracks to answer.
2hrs later....... just had a look at the manual that came with the bike, which is for an '87 model and it clearly show's a twin pot caliper front brake, with the mounting bolt's much wider than mine.....I'd say that's what it came from.
« Last Edit: February 10, 2009, 02:03:23 pm by evo550 »
Offline BAHNZY
Re: WP4054 Forks
« Reply #33 on: February 10, 2009, 09:34:58 pm »
Rod (BAHNZY) Bahn
Re: WP4054 Forks
« Reply #34 on: February 10, 2009, 09:45:33 pm »
could be it. going back to the catalogue i think any of these should be right
CR/WR (87-88) & 88 4 strokes - with double piston caliper  (and probably XC aswell)
Re: WP4054 Forks
« Reply #35 on: February 10, 2009, 10:06:36 pm »
That's the one, although shit of a photo for your purposes, could email him and ask for measurements of mounting bolts.
