Clubroom
Tech Talk
CR Kickstart pinion gear
Topic: CR Kickstart pinion gear (Read 1836 times)
Boyracer
C-Grade
January 25, 2009, 03:41:08 pm »
Now that I have finnished the CR250RE project the kickstart has decided to slip and they are NLA, is there any aftermarket supliers for these or is it a chse the wreckers job, any help appreciated trhanks.
Re: CR Kickstart pinion gear
January 26, 2009, 02:20:58 am »
As far as im concerned, ebay is your best friend when it comes to stuff like that. Make sure you look in ebay stores as well.
STW996
January 27, 2009, 07:08:44 am »
Hey Boyracer, I had that problem with one of mine, if you find someone who sharpens machine cutters (tooling or a gear cutter) they will be able to back cut the teeth and will work ok from there.
Where about's you at?
Clubroom
Tech Talk
