Author Topic: SUZUKI TM PIPE  (Read 7353 times)
Re: SUZUKI TM PIPE
« Reply #15 on: January 27, 2009, 09:49:58 am »
thought i wasnt going mental............. just yet
Offline holeshot buddy
  • sunshine coast qld
Re: SUZUKI TM PIPE
« Reply #16 on: January 27, 2009, 10:02:47 am »
so what do you think it is
it is bigger than it looks in picture
i would say minimum 250
it has clearance dents on it (genuine)
maybe someone can recognise the model ;D
it is genuine no mods or dents ;)
follow me to first turn
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: SUZUKI TM PIPE
« Reply #17 on: January 27, 2009, 10:28:48 am »
Read my post and take it as gospel IT IS A modified 185 hop-up kit pipe
Ban BLACK rims NOW
Re: SUZUKI TM PIPE
« Reply #18 on: January 27, 2009, 10:51:12 am »
dont shoot the messenger ;D ;D
Doc
Re: SUZUKI TM PIPE
« Reply #19 on: January 27, 2009, 11:13:16 am »
here's the TS185 RT kit pipe for comparison..I spot some big differences..it's not 185 ;)  I'd near go as far to say it's not Suzuki, Kawasaki maybe? possible it's TM/TS400 also :-\ the rear mounting design should be helpfull for ID
« Last Edit: January 27, 2009, 11:33:22 am by Doc »
Re: SUZUKI TM PIPE
« Reply #20 on: January 27, 2009, 11:47:14 am »
It has 2 dent on the neck like it should have a few spring or its clearing somthing on the frame like the motor plates, that also might help.
I just dont like the end cap the way the end cone just stops, ther is somting in that , could it be some kind of roar/ endure pipe ? like an early TS ?  Somthing that uses a big Mother muffler
Re: SUZUKI TM PIPE
« Reply #21 on: January 27, 2009, 08:45:37 pm »
 Cyclegod posted this one way back in March 17, 2008
 Notice the same factory frame cleareance dents on the back
squirtmoto
Re: SUZUKI TM PIPE
« Reply #22 on: January 27, 2009, 08:48:52 pm »
here's another pic
squirtmoto
Re: SUZUKI TM PIPE
« Reply #23 on: January 27, 2009, 08:52:43 pm »
another
Doc
Re: SUZUKI TM PIPE
« Reply #24 on: January 27, 2009, 09:30:29 pm »
could be a TS250 RT kit pipe. The angle and size of the header is somewhat different to the 185 kit pipe resembling more a 250 as Bill and Russ mentioned. The mount I cannot place excepting I have seen it on some smaller TS models (100 and 125's) it may fit a TM250 but only the early model as the header angle changed slightly in '74 'I think' I don't pretend to know everything but it isn't RH and it isn't TM250 or 400 so there aren't too many other options. The pressing and indentations do look more like the kit pipes. I'll have an half educated guess and say it's '71-'74 TS250 never seen a 250 kit pipe but I do know there were some that exited stage left and some stage right. Just trying to picture where it would mount on a TS and I imagine the cutouts at back tuck it closer to the frame and the higher mount would then go close to fitting the stock TS up pipe lower mounting bolt hole :-\ try it on a frame for sure and see but yup..I go TS250. ;)
« Last Edit: January 27, 2009, 09:32:40 pm by Doc »
Offline JC
Re: SUZUKI TM PIPE
« Reply #25 on: January 29, 2009, 09:08:38 am »
Seems to me that Doc is on the money (again).
TS/TM250 pipe exited from barrell on LHS; 185 on RHS. This pipe appears to exit on LHS & two dents in header would be for front engine mount bolts. Looks to me to suit 71-73TM250 or any TS250 to 76 'A' model.
One way to make certain if its 250 or 185 - measure header OD at ex flange: 250 OD 51mm apx; 185 OD 46mm apx
