Author Topic: yamaha parts again  (Read 3467 times)
Offline frostype400
yamaha parts again
« on: January 13, 2009, 09:47:51 pm »
since i had a succes providing pics in my last add i will do it again does any one have or know where i can get these i need a seat the same as this metal base same mount as mx or gt80 and also need one foot peg pin that hold the peg in place it is on a few bikes it is like a bolt but no thread or nut involved just a split pin through one end also need horn and indicators and mudflap on front guard and new footpeg covers for both front pegs and buddy pegs and one for front gear stick i know they are on ebay but if some one has the covers locally that would be better i need a real gt80 nut to tell me what is the go with where indicators are mounted on the aus models and wether we had yamaha mini or enduro 80 on our oil tanks thanks Michael.
1971 tm400 and PE's
Offline frostype400
Re: yamaha parts again
« Reply #1 on: January 13, 2009, 09:48:41 pm »
heres a photo to go off
1971 tm400 and PE's
« Reply #2 on: January 13, 2009, 10:26:03 pm »
what diameter pin is it? heres a tip, go try your PE foot peg pin, it may work, or just get a long enough bolt with enough shank, cut off thread and turn down hex to a flat/dome shape and drill hole for split pin, and get in zinc plated. easy. but it will be even easier to ring a yamaha dealer for that part. im sure a dealer in AU has foot peg pins, they probably fit many bikes across the range.
if i had a yamaha zedder programe i would be able to tell you what bikes have that same pin but i dont. im sure someone on the forum has a yamaha zedder
Offline frostype400
« Reply #3 on: January 13, 2009, 11:28:06 pm »
ok thanks Leith so the footpeg pin is a easy part to make i think someone will probably have one if not there is an easy way out thanks Michael. :)
1971 tm400 and PE's
Offline YZ250H
  • Back in QLD Baby !
« Reply #4 on: January 14, 2009, 05:52:28 pm »
Part # 91701-08038-00
Fits 340 models, so fair chance you will be able to buy one from Mr Yamaha.
Offline frostype400
« Reply #5 on: January 14, 2009, 06:55:54 pm »
thanks could i also get the rubbers of the footpegs and buddy pegs from a dealer?thanks Michael.
1971 tm400 and PE's
« Reply #6 on: January 14, 2009, 07:15:02 pm »
give them a ring and ask them. you wont know till you ask ;D, but i think its highly likely.
Offline YZ250H
« Reply #8 on: January 14, 2009, 07:21:44 pm »
and http://www.speedandsportinc.com/
and http://www.zedder.com/msg9.htm
and http://stores.ebay.com/Zedder-Motorcycle-Software_Yamaha-Software_W0QQcolZ4QQdirZ1QQfsubZ12514820QQftidZ2QQtZkm
they should help you
and if you want to shop in Australia, try your local yamaha dealer or try yamaha pitmans or yamaha retro spares in Adelaide ( i already given you their details i think?)
« Last Edit: January 14, 2009, 07:26:55 pm by LWC3077 »
Offline frostype400
« Reply #9 on: January 14, 2009, 07:33:19 pm »
thanks i have the part numbers i need have spoken to speed and sport the dont have the seat or indicators i just got some rear indicators off ebay and i only need a few little things now and its complete heres some parts # if any one can use them Front indicators 260-83310-35-93 subs to 353-83310-36-93.Seat 376-24730-00 subs to 376-24730-01 subs to 2A4-24730-00 if someone finds these that would be great thanks Michael.
1971 tm400 and PE's
