Author Topic: 1974 Yamaha YZ 360B  (Read 20533 times)
YZ360A
Re: 1974 Yamaha YZ 360B
« Reply #15 on: September 15, 2007, 10:24:58 pm »
Beautiful vandy looks as if this will do a yz360a and B's aswell as the 214 rod does a number of bikes including the yz250a yz360a and the b models also.
Look's like rosco is on a winner for the money.
I do prefere oem though for my bike's if I can find the parts etc.
Did the pro x have a slot on the big end for lubrication??
Cya Adam
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #16 on: September 15, 2007, 10:28:52 pm »
seems we could talk about rods for a while hey.
yes to the slot.
i definetly remember checking it out, the old 214 just has a hole while the pro x has a very nicely shaped, well lubricating, almost sexy, slot.
"flat bickie"
« Reply #17 on: September 17, 2007, 09:26:04 am »
Gents - this is awesome help - thanks.  Apparently the spacer is needed with the Honda rod but yep the Pro X fits straight in!
regards
Rossco
Offline vandy010
« Reply #18 on: September 18, 2007, 01:34:17 pm »
i'm just wondering about sleeves for these things.
from a riding point of view, would an oversized Rt2 or 3 piston work in the YZ?
or even a Dt360a piston kit? just wondering as i know RT1 oversizes can go up to 2mm or does the yz360a run a chrome bore?
"flat bickie"
« Reply #19 on: September 18, 2007, 04:08:00 pm »
and while you are talking about sleeves - does anybody know where you can get one of those?  I am having good luck so far with pistons, rings, rods but need a sleeve and just starting to chase a gasket set.
ta again
Rossco
« Reply #20 on: September 18, 2007, 07:54:23 pm »
a 360 sleeve might be an odd one.  google LAsleeves etc they are online so you will at least know if they made em.
i have the RT1/2/3 360cc gasket set, check to see if they are the same if so i have a few of em :P
« Reply #21 on: May 14, 2008, 11:53:15 am »
i found a guy who custom make steel liners for under $400 fitted.  top effort i think and the windows will be lining perfectly to the bore cuts
Offline RED ALERT
« Reply #22 on: June 10, 2008, 08:40:59 pm »
A sleeve for my 360B arrived from LA Sleeve today. They no longer list it on their website, but they do have them.
Part No: YA-332.
$230 USD + postage. Arrived at my door for $300AUD.
The problem I now have and hope some of you Yammie gurus can help me with, is the pistons I had sourced as YZ360 pistons
have turned up and they are in fact I believe RT360 and RT2 MX pistons. Part No's 332-11635-01 & also an oversize 322-11630-10.
My trusted mechanics are concerned that the cut-aways in the back of these pistons are different to the origianal and more importantly think the position of the ring locating pin is wrong and will cause the ring to catch on an intake port.
Can any of you guys help with your experience/knowledge, or should I keep hunting for genuine YZ?
Rod
« Reply #23 on: June 10, 2008, 09:51:38 pm »
ROD
just change the pin on the piston ring grove to were the yz one is
« Reply #24 on: June 12, 2008, 07:11:32 pm »
Rod - back in Perth on Sunday - I have YZ pistons if you need - also MX pistons will fit if needed!!
Rossco
Offline RED ALERT
« Reply #25 on: June 13, 2008, 12:05:05 am »
Cheers Rossco,
How long are you in town for before heading off again? I am racing in Busselton on Sunday but hopefully catch up with you soon.
Trust ya had a ball in Tas. :)
« Reply #26 on: June 13, 2008, 09:39:56 am »
had a great time Rod - 360 went very well for it's first outing!!!!!  I am in Perth until the following weekend.
Give me a call and we can work out a plan?
cheers mate.
