Author Topic: how to fill ohlins with oil?  (Read 2688 times)
Offline Kane Mcguire
« on: December 28, 2008, 08:38:18 pm »
 i have ohlins on my 250cr husky and want to know how to fill with oil. i was told to keep filling up into the hole at the top of the reservoir till full. it takes ages, a lot of filling then putting the plug back in, pumping the shaft, then putting more oil in. trying to displace the air.  not sure if this is correct.
YSS
Re: how to fill ohlins with oil?
« Reply #1 on: December 28, 2008, 08:56:01 pm »
See Fernando at Husky Parts in Sydney he will be able to help . Regards Walter
« Reply #2 on: December 28, 2008, 09:04:19 pm »
you need these manuals. tells you all in there.
http://www.husqvarna-parts.com/catalog/item/3736874/3414914.htm - there are workshop manuals in this lot plus parts books and valving specs etc
he usually sells these on ebay too. these manuals have recently been updated this year when i loaned my manual to Phillip to copy the info he was missing in the remote reservoir manual.
http://pureenduro.free.fr/Div/OhlinsJPC/OhlinsOverhaul.pdf
http://pureenduro.free.fr/Div/OhlinsJPC/eclate%20OLD%20MX%20TWIN%20SHOCK.pdf
« Last Edit: December 28, 2008, 09:21:18 pm by LWC3077 »
Maico31
« Reply #3 on: December 28, 2008, 09:22:25 pm »
To refill the ohlins with oil you need to let the gas out of the reservoir and pull the seal head and shaft out of the body and drain and refill the body with oil then bleed the shock before assembly and regas. It's not a simple job if you've never done it before.
YSS
« Reply #4 on: January 09, 2009, 10:37:09 pm »
Dont forget to read the book  ;)
