Clubroom
Tech Talk
Exhaust coatings
Topic: Exhaust coatings (Read 2381 times)
E74
Exhaust coatings
December 18, 2008, 08:29:39 pm »
Just had these 4 pipes done by high octane performance coatings, they were all "New" before they were coated as apparently they wont do used 2 stroke pipes, $170 each for the silver and $210 for the black , stunning results but damned expensive!
Last Edit: December 18, 2008, 08:33:29 pm by E74
LWC82PE
Superstar
Re: Exhaust coatings
December 18, 2008, 09:57:17 pm »
what about if you burn the inside out of old 2T pipes first? will they do them then? ive done that before and it gets them back to bare clean metal and no oil at all. creates shit loads of smoke though
090
December 19, 2008, 06:36:39 am »
What is the black coating? Looks good.
I was told that they refuse to coat an old pipe as it will contaminate the solution/product used to coat it ,so they wont risk a second hand pipe no matter how clean.
E74
December 19, 2008, 07:41:36 am »
The black is a second process , it can't be done without the CeramaKrome going on first, it is then given a coat of satin black "color-guard".
http://www.performancecoatings.com.au/benefits_exhaust.html
Last Edit: December 19, 2008, 07:43:24 am by E74
Clubroom
Tech Talk
Exhaust coatings
