Author Topic: Fluids and capacities for the KTM 420  (Read 2825 times)
Denis
« on: December 06, 2008, 01:18:05 am »
This weekend I'll be working on the KTM and was wondering about fluids.
What I should I use for the gearbox, engine, clutch, and what is the correct ratio for the fuel? The fuel mix for the Montesa is 42:1.
Thanks, all!
oz555ktm
Re: Fluids and capacities for the KTM 420
« Reply #1 on: December 07, 2008, 12:25:05 am »
I use Dextron 3 Auto trans oil or vmx80 gear oil Castrol .
allways use 25 to 1 supper tt castrol
Denis
« Reply #2 on: December 07, 2008, 03:13:52 am »
Thanks! Wow, 25:1? That's a pretty high ratio!
oz555ktm
« Reply #3 on: December 07, 2008, 10:44:32 pm »
muffer packing is cheep.
Piston and Rod is Not ..
and if you ride a ktm as you should .
Flat out .
See vmx mag no# ? the evo 250 test .
and I run  my 125s on 16:1
