Author Topic: Ohlins shocks  (Read 3148 times)
Offline KB171
Ohlins shocks
« on: November 30, 2008, 01:43:58 pm »
Anyone know what gas pressure to whack in a set of blue piggy backs off an 81- 82 ish husky?  ??? aint got SFA in em at the moment,
  Cheers KB171
Re: Ohlins shocks
« Reply #1 on: November 30, 2008, 02:20:07 pm »
for the normal ohlins its around 180-200 PSI but depends on what brand bike its on. i reckon i have ITC spec, so will go find out.
well i found out XC 500 with ITC ohlins has 185PSI i would start around there.
« Last Edit: November 30, 2008, 02:24:29 pm by LWC3077 »
Offline KB171
Re: Ohlins shocks
« Reply #2 on: November 30, 2008, 02:37:24 pm »
I've put them on my Honda RZ 250 .bit of a stab in the dark experiment,  ::) they fit and seem to work ok with the forks,but need gassin up before i go an start bouncing off things, That should put me in the ball park,thanks mate.
Maico31
Re: Ohlins shocks
« Reply #3 on: December 01, 2008, 07:25:23 pm »
You'll find those ITC ohlins don't have enough shaft travel on a Honda and you won't get the same amount of rear wheel travel and they will probably be a bit stiff. Those Husky's have a higher leverage ratio than most bikes.
Re: Ohlins shocks
« Reply #4 on: December 01, 2008, 08:26:51 pm »
I should have specs for ohlins fitted to Honda CR’s. what year is the RZ? 78/79? I can tell you exactly the length they should be and the travel, valving etc. just send me a PM if your interested.
« Last Edit: December 01, 2008, 08:28:56 pm by LWC3077 »
Offline KB171
Re: Ohlins shocks
« Reply #5 on: December 01, 2008, 08:42:13 pm »
They are 17.5 inchs  and with springs off gets full travel i believe ,tyres about 40mm from touching the underside of the gaurd. the model number is HA0505.yes they do feel a bit stiff. I was hopeing a fresh gutfull of gas might make em a bit better  :-\  1979 RZ
« Last Edit: December 01, 2008, 08:44:52 pm by KB171 »
Re: Ohlins shocks
« Reply #6 on: December 01, 2008, 08:57:58 pm »
yes i do have spec sheet for ohlins on 78/79 CR 250. will scan and email tomorrow if you let me know your address.
have you got or do you need a manual or parts list/diagram
« Last Edit: December 01, 2008, 09:00:41 pm by LWC3077 »
Offline KB171
Re: Ohlins shocks
« Reply #7 on: December 01, 2008, 09:08:35 pm »
PM sent Thanks Mate.
