Author Topic: BSA frame numbers  (Read 4801 times)
Offline jimson
  • Sanctuary point N.S.W
BSA frame numbers
« on: November 28, 2008, 11:04:51 pm »
G'day viewers does a BSA frame have the frame numbers on the bit of the frame between the triple tree. I have a frame and I think its a 1969 250 Starfire  but I can't find the bloody frame numbers  ??? jimson
Offline grouty
Re: BSA frame numbers
« Reply #1 on: December 01, 2008, 01:18:30 am »
On some of the pre- OIF models the frame number is located on the front engine mounting bracket. The part welded to the frame.
Thumpers Rule !
« Reply #2 on: December 01, 2008, 06:06:15 am »
check out this web page for info
http://www.britbike.com/
« Reply #3 on: December 04, 2008, 09:49:20 pm »
try on the down tube, just down from the headstem on the left side. they are only stamped very faintly, numbers could be filled in with paint.
i will see if i can find out where it should be on your particular model and let you know
« Reply #4 on: December 10, 2008, 05:24:52 pm »
i cant seem to find what book said where the numbers are located but it should be in either of the areas already mentioned
« Reply #5 on: December 26, 2008, 04:35:18 pm »
« Last Edit: December 26, 2008, 04:43:49 pm by LWC3077 »
« Reply #6 on: May 31, 2009, 02:05:46 pm »
A7 and A10 are models of twin cylinder BSA's
http://www.bsansw.org.au/what_bsa.htm
« Last Edit: May 31, 2009, 02:09:34 pm by LWC82PE »
